d16 turbo help
Old May 27, 2016 | 07:23 AM
nokehockey20's Avatar
Default d16 turbo help
hey guys, I just had a quick question for everyone. I just installed a turbo kit on my d16y8. the thing is, I ordered a chipped p28 ecu to put in right before tuning but I have to travel about 3 hours to closest reputable tuner. my wastegate spring now is set to 8psi which is around what I want to tune on. I will be using bigger injectors but im going to install them when I put the ecu on. ive got a fmu and missing link laying around. so my question is will everything be ok on stock injectors and ecu with fmu and walbro 255 fuel pump for now until I can get it tuned right? thanks
Old May 27, 2016 | 07:55 AM
Dark_Teg's Avatar
Default Re: d16 turbo help
Get a base map for the bigger injectors and get it tuned. Its better to do things right and enjoy the car rather than half assing things and paying for parts twice.
Old May 27, 2016 | 08:02 AM
Yeah I know that. That's what I'm doing. I'm asking if it will be safe un til then. I'm talking a matter of lke 2-3 weeks max and taking it easy. I'm just asking if the car was to see 8lbs on stock map and Injectors even with fmu will it be alright?
Old May 27, 2016 | 08:07 AM
boosted94gsr's Avatar
If it was my car I'd wait until it's tuned properly before it sees any boost. You could drive to the tuner with the stock ecu, map, and injectors staying out of boost 100% then just swap injector and ecu when you get there.
Old May 27, 2016 | 08:09 AM
Yeah I understand that, that's what I plan on doing. But being that the turbo is so small it will most likely be hard to stay out completely when traveling uphill or something like that
Old May 27, 2016 | 08:45 AM
Disconnect the charge piping too.
Old May 27, 2016 | 10:25 PM
EsotericImage's Avatar
Retired Moderator
And toss the FMU and missing link in the trash on the way to the tuner
MurtazaDSM
Nov 23, 2011 09:08 AM
Niskyspy
Nov 19, 2006 06:59 PM
Slow Ek
Aug 16, 2006 06:41 AM
petergriffen
Jul 24, 2006 07:35 PM
gsrboosten
Mar 26, 2006 07:02 PM
