S300 special wiring for VX
Old May 20, 2016 | 04:49 PM
SiRCiviC94's Avatar
Default S300 special wiring for VX
Wiring boost solenoid to vx ecu harness
I can't use A11 it's a main ecu ground on this harness, or can I and share it? Maybe?
Ideas ? There's other grounds but not sure I can eliminate any.
With a11 cut and used for the solenoid the car won't run until i hook up the laptop
Need this done right !
Old May 23, 2016 | 05:54 AM
jayswizz's Avatar
Default Re: S300 special wiring for VX
well it looks like someone has been in there prying those plugs out of the ecu about a million times, so who knows what the hell is going on, a11 is supposed to be for an egr valve not a ground wire. try sharing it first if not move that sucker over to another ground spot on ecu and see what happens
Old May 23, 2016 | 10:14 AM
LightningTeg's Avatar
Community Builder
Dont matter what the car is, whats the ECU?
Old May 30, 2016 | 03:43 AM
SiRCiviC94's Avatar
Figured id update , car works fine it's the only one in the world that shares that wire I have a joint a11 orignal wire , boost solenoid shared.
Clip damage, cars had the ecu in and out over 500 times, lol poor clips
Old May 30, 2016 | 03:44 AM
SiRCiviC94's Avatar
It's a p28
slogfilet
10
Aug 18, 2014 06:55 AM
Coopa B18c5
Dec 14, 2012 06:13 AM
Hegster
Mar 20, 2007 12:04 AM
RCautoworks
Mar 2, 2006 11:37 AM
