Need advice for my d16y8
Old May 26, 2016 | 01:34 PM
Bothzanova's Avatar
Default Need advice for my d16y8
First question : i want to turbo charge my stock d16y8 which turbo should i use?
Secondly for the ecu any suggestions ? I have f-con 2.1 ecu is it good enough ? Or i shall use other ecu thanks
Old May 26, 2016 | 01:53 PM
2kdrift's Avatar
Default Re: Need advice for my d16y8
not enough information we need power goals and purpose at minimum
Old May 27, 2016 | 12:30 AM
Bothzanova's Avatar
I just want around 200 hp with stock internals, will it push the engine to hard?
ps. I use it in daily life every day will the engine life be shorten down?
Old May 27, 2016 | 01:11 AM
Xanthias's Avatar
All your questions are answered by a simple search on google with a honda tech on the end of it. Plus there are faqs on the top of the page which indicate everything you need to know. D series rods are pencil thin so above 200 is risky. Also for 200 its barely worth the money, go buy a b18c and it will be much easier rather than boosting an engine that was designed for grocery getting.
devoncll1
Mar 10, 2017 11:21 AM
Houselect
Jun 11, 2016 03:43 AM
mrperformance
May 17, 2012 03:03 PM
Killa From Manila
Mar 6, 2007 11:28 AM
