Radiator drain plug replacement possibilities?
Old Sep 9, 2016 | 12:13 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Radiator drain plug replacement possibilities?
just like the title says. i replacement the o-ring on the drain plug on my radiator from go autoworks (civic half core) but it seems that i may have a drip leak. but im looking for a better solution for a drain plug that will not leak. any suggestions?
Old Sep 9, 2016 | 12:20 PM
Dark_Teg's Avatar
Default re: Radiator drain plug replacement possibilities?
Get an adapter that goes from the drain plug thread to a -6an and cap it with a -6 an cap. I have a -6an line running to my drain from the turbo. when i need to remove the line for some reason i put a -6an cap on. doesnt leak.
Old Sep 9, 2016 | 12:41 PM
something like this?
Dorman Radiator Drain Plug 61102- ReadReviews onDorman #61102
Old Sep 9, 2016 | 02:46 PM
TheShodan's Avatar
Moderator
You're running water lines aren't you? I thought you were with what you had? So, just do what Dark_Teg suggested but instead of capping it off, run it to the turbocharger.. Easy Peasy, nice and Breazy..
Old Sep 9, 2016 | 03:37 PM
2kdrift's Avatar
different radiators use different threads, make sure you get the correct size and pitch fitting... I think the AN is a great idea, you can easily cap it off and if you ever need a water line for turbo etc its available
Old Sep 9, 2016 | 04:25 PM
boosted94gsr's Avatar
Here is a pic of the -6an adapter I run on my tucked radiator. I think I paid $8 for it off eBay. Just make sure you get the correct thread size and pitch for your particular radiator.
Old Sep 10, 2016 | 03:25 PM
thanks for the info guys. comes to find out that i had to turn the drain plug a 1/4 turn to stop it from leaking.
tercelrcr
Jan 8, 2012 02:35 PM
darwin1859
Jan 3, 2010 04:47 PM
camera obscura
Jul 13, 2004 06:04 PM
E-AT_me
10
Sep 21, 2003 11:04 AM
FD3S
Apr 20, 2003 04:22 PM
