Holset HX35 compressor vband flange
Old 07-29-2016, 09:33 AM
NWDyno's Avatar
Default Holset HX35 compressor vband flange
Hey guys. I am looking for the vband flange (and clamp) for the compressor outlet on a Holset HX35. I know Dodge makes a cast aluminum elbow piece beings the turbo is from the Cummins, and I figured I could easily find just the compressor vband flange and clamp but having a hard time. I know I can get the cast aluminum elbow and cut the flange off, but thought I would ask before I find another route. Thank you.
hx35/hx4/s300 turbos are all the same with respect to this compressor outlet flange...just cant find the darn thing in aluminum.
Old 07-29-2016, 09:43 AM
NWDyno's Avatar
Default Re: Holset HX35 compressor vband flange
guess I need this but in aluminum
Stainless Diesel S300 V-Band Compressor Outlet Flange SD-S300CVOF
Old 07-29-2016, 10:43 AM
Dark_Teg's Avatar
My V-band compressor housing is made of stainless steel. Aluminum would melt if used for a compressor housing.
Old 07-29-2016, 10:51 AM
NWDyno's Avatar
Weird....every single turbo I have used has an aluminum compressor housing and steel turbine. What turbo do you have that has a steel compressor housing?
Old 07-29-2016, 11:53 AM
2kdrift's Avatar
x2, and no compressor housing does not get nearly as hot as turbine housing so it does not get anywhere near melting point
Old 07-29-2016, 07:02 PM
B and B's Avatar
Lol, he was just mixing up the two, no doubt.
Man...vband **** is priced on a structure similar to eyeglasses...Ripoffs abound
Old 07-29-2016, 09:20 PM
Moderator
TheShodan's Avatar
Not for when you want the quality ones that don't warp after 2-3 times attached.
It's the turbo world..man up, soldier. (Or reach into that pocket, whichever analogy you choose) ;-)
Old 07-29-2016, 11:24 PM
TravisBiggie's Avatar
thats what you want.
my buddy is using a ebay 2.5" ebay vband with his hx35 outlet, it seems to work, but idk?
I have a hx35/40 sitting here, haven't decided if i'm shaving the lip off, or use the 2.5" if it works on my buddies car. its done, just not tuned yet.
Old 07-30-2016, 06:41 AM
NWDyno's Avatar
Thank you. I will see if I can find a 2.5 vband laying around, see how well it matches up. Beings its a Dodge turbo, I assumed its was some odd/OEM only size
Old 07-30-2016, 11:50 AM
Moderator
TheShodan's Avatar
Different aluminum grades have different flash points of melting. So we can all drop this semantic bickering now..
Find a flange or don't use it..you'll be fine
Old 07-30-2016, 12:22 PM
NWDyno's Avatar
Thanks a bunch. Not mine, it's a customers car.
Old 07-30-2016, 03:01 PM
I forgot to mention he put a metal o ring inside of the outlet of the compressor housing, but I don't think that is going to help anything since the seal of the vband seals on the flange itself.
Old 07-30-2016, 05:55 PM
NWDyno's Avatar
Oh ok, thank you for the info. I am going to dig for a flange and try it out!
NWDyno
Welding / Fabrication
07-29-2016 10:20 AM
GPoodle
12-09-2003 10:57 AM
johnisenglish
10-28-2002 06:40 PM
CovertFI
06-26-2002 10:15 AM
Quick Reply: Holset HX35 compressor vband flange
