Anyone running Type R cams...Vtec engagement point??
Anyone with type r cams, whats your vtec engagement set to?
I know its specific to every setup and needs to be found on the DYNO, unfortunately my tuner didn't take the time to do this, I know because my basemap and my current tune have the exact same settings. Just looking for people that have experience with this and the general range
lower boundry set to 4800
upper boundry set to 5300
Actually seems kinda low for ITR cams, pretty sure my basemap came off a car with gsr cams
Type r head/cams
gsr block 9.5:1
skunk2 ultra street IM
Ramhorn Manifold
Boosting @17 PSI
Type r head/cams
gsr block 9.5:1
Ramhorn Manifold
Boosting @17 PSI
Re: Anyone running Type R cams...Vtec engagement point??
I wouldn't go changing your vtec engagement point unless you know for a fact your tuner tuned the whole low cam and high cam maps.
I could definitely see some so called "tuners" being lazy and not fully tuning all the maps. That could turn into a major problem if you start moving vtec crossover around to an untuned part of the map.
Yeah when I tune mine the plan is to tune the low cam maps from idle to about ~7k rpms, then tune the high cam maps from ~3k rpms to redline. Once that's done I'll play around with the vtec crossover point.
nice would you or someone mind sending me a screen shot on the low speed ignition....sometimes pulling out of my driveway its supper stumbly I noticed when I had my dizzy retarted it was way worse, 1k-1.5k is set to 18 degrees after that it smoothes out and also my ignition is set higher after this part
You could post up a screen shot of your ignition maps for some input too. What are your afrs doing when it stumbles?
You tune low can get the baseline then tune vtec and see where the engine wants the crossover to happen. Every engine is different. If your tuner doesn't know these basic steps find a new one
If you're tuning your self get on a dyno and see where the engine wants it it's pretty clear to figure out
first pic low ign second pic high ign
Wish it was that easy Theres only one shop out here and the others are freelance guys...I am starting to think I need to learn it, need to get to know this more and have more confidence in making changes dont wanna blow anything up lol
Your ignition map looks nice and smooth. Your stumble is definitely afr related. You would need to add fuel to the low speed fuel map where it's going lean. Try to keep it as smooth as possible, for example don't just add 10% to one cell and make a huge spike. Try to taper it into the surrounding cells. It helps to look at the 2d fuel map when you do it to make sure it's still smooth. Just make small changes, log and check afrs, and repeat until your problem is resolved.
I will check my phearable base map in that area as well as I dont remember having the stumble before I took it to the local tuner
quick question does my high speed ignition look too conservative ? this is on 17PSI
Ohh and by the way on dyno day he didnt have access to AFR via logs, cuz we couldnt figure out how to hookup the wires properly at that time....I had to do that myself I needed to hookup the analog ground from my aem wideband into the hondata internal connector
Dude! thankyou so much!!! for holding my hand on this it really helps. Yes When I was studying the maps I noticed everything used gradual increases for a smooth transaction, I was already thinking I should do what you just said but this gives me alot more confidence that I was correct ...thanks again
1st low ign
2nd high ign
Getting closer lol but that only shows up to 11.9psi. Your at 17 right. Baby steps haha but we'll get there.
