Back from the dyno - 84mm Type R - 500whp goal
For starters, I just finished my car not long ago and it has been a long time coming.. I started this whole engine build with the goal of trying to make 500whp on pump gas safely. I'm realizing how hard that is to do
Benson sleeved 84mm Type R
9:7:1 cr CP Pistons, Eagle Rods
Supertech valvetrain
ARP Main studs
Go Autoworks 2.5 inch piping
Go Autoworks Turbonetics TGA 6157
BRMS Mini ram manifold (AC/PS comp)
Grams 1000cc fuel injectors
Walbro 255 w/stock FPR
NGK BKR7E11
Got my car on the dyno.. my tuner built the map and we did a couple baseline pulls
She made 302whp and 219 tq on 8psi and then we ran into issues..
I feel like an idiot for being under prepared and not having my car ''ready'' or to at least keep pushing it, so now I have to get some things situated and I am going to go back.
On to the issues
We eventually increased the boost in small increments and we ended up turning it up to 16psi and it started throwing spark and breaking up. 16 psi at 5800 rpms we were at 75% injector duty cycle and he said we probably would have been up to 85/90ish.. running out of fuel
Sadly I do not remember what I gapped my NGK BKR7E11 plugs at. The car has sat for so long in the garage, but the build only has 1100 miles on it.
I searched around and found a bunch of OLD threads with people making high HP on gas and I know stuff has changed.. I just wanted to see if I'm crazy for wanting to make 500whp. I don't necessarily have to keep it @ that for my weekend driving, but it's just a goal for me. I don't think this turbo is going to do it.
At this point I am contemplating switching to E85, but I know it's going to be expensive.
I guess I am going to replace plugs, get an aftermarket fuel pressure regulator [aeromotive a1000] and try to stick with the walbro 255 or should I step up to a walbro 450 for future just in case?
IF i kept it on gas and I believe we have leaded race gas available around here. I guess i could turn it up on that and see what it makes?
ARP Main studs
NGK BKR7E11
On to the issues
Re: Back from the dyno - 84mm Type R - 500whp goal
I dont see anything wrong here except plug gap is unknown. Need a fresh set of plugs and gap them down to 0.020 or so. If you're still on pump you may need a colder plug.
And your tuner sent you home without checking this stuff?
I have been asking TheShodan all kinds of questions and some of the local guys run the non resistor on their setup.. they are only a little bit more $. I am thinking about trying those.
Man U FTW
BKR7e, NOT the BKR7e11's. The -11s have a .044 gap whereas the 7E's have a .030 gap IIRC. Dont bother with the -11's because you'll end up gapping them all down anyway
If you switch to E85, grab a Walbro 450 and some bigger injectors, you'll be fine (12-1600cc)
I have blown up enough things on pump gas. Straight E85 for me and I have the same goal as you. Well my goal is to run 10's....500whp should make that goal easy. I thought about running C16 but when you compare C16 to E85 dollar wise the choice is clear.
Moderator
$/gal sure. But you have to take into account all the hardware and equipment as the initial investment. (differing fuel pump, fuel lines, sensors, purging injectors, etc)
With my C16, I can concentrate on other aspects of the car for effective circuit racing. Which I don't do enough to worry about the fuel cost. Many of us in Michigan/Illinois pick it up in bulk from all of the domestic drag racers that still buy by the 55 gal drum.
I guess I'm still in the minority... Meth/water or C16 for me. I have E85 stations all over me.
Make sure you get BKR7E, not the 7E-11's. I just ran into this problem with it blowing spark out on my LS. I got BKR7E's and gapped them to .030". Fixed in a heartbeat. I tried running the 7E-11's and it kept blowing spark. Part number 4644 at Advanced Auto. With your boost pressure and power level I would gap them lower in the .020".
You think 1100 miles is low for plugs? Hell, I went through about 5 sets of plugs with like 50 miles on most of them, Trying to get them right.
I ran 4554 with no interference issues, but I used NGK plug wires that have resistance built into them I believe.
@op I wouldnt bother replacing the fuel pump unless you go E85
sounds like your plugs were not gapped correctly. You can make alot more then 300HP with that turbo on pump, I tend to agree with lighting here I dont see any reason you cant meet your goal with what you have. FPR is always nice to have. Those injectors should do 500HP no problem
My tuner recommended these as well, he had me gap them to .025, on my 7e's I was using .028-.03 I retune this weekend
One other thing.. I just pulled the trigger on the aeromotive a1000 FPR and gauge. I checked the FAQ and searched on here and google and there isn't a solid install with pics.
I have a chasebays tucked fuel line kit with an inline filter going to my skunk 2 composite fuel rail... the factory FPR is bolted onto the rail and on the end of the fuel rail I am running a -8 [i believe] an o-ring cap blocking it off.
I am kinda confused on this FPR install because it has two ports up top. It looks like one will get blocked off? Does it come with the cap to block it off? How are the hoses routed? I would probably understand it better if someone could post some pics..
I appreciate it
Looks like it has a feed and a return to the fuel tank, I run the standard aem rail mounted unit so I cant help much here.
http://aeromotiveinc.com/wp-content/...0109-0revH.pdf
so basically you put a plug where the factory FPR goes and follow one of the 2 images below
If you have room you can actually put the gauge on the FPR, right?
Do you have any other pics or close up? Where you mounted it? I am pretty sure I grinded down the studs on the firewall when I had my bay painted. I was thinking about using some self tapping hardware or something..
Is that [1] 90 and then a straight?
2kdrift, yeah i seen that but also read to never put the FPR before the rail or whatever.. then i noticed in their instructions they mentioned it too.
Its -6an 45 off stock hardline feed using B&R adapter feed, to -6an 90 top of filter, -6an 90 off bottom filter to -6an 90 at fuel pressure gauge adapter, fuel pressure gauge adapter to -6an ORB fuel rail fitting, other side is -6an ORB fuel rail fitting to -6an 90 to -6an 45. Stock return line is only 1/4" so I had to step it down from 5/16 out of bottom of regulator.
I used self tappers to mount it to firewall. But it would be easy to pop off the cowl and put bolt with nut.
did you need to use any type of thread sealant when you used the oem fpr block off plug?
More pics for Jimmy
Yea mine leaked from my fuel gauge port, I was just curious I ended up using this aviation sealer stuff since teflon is not meant for fuel
