D16Y8 turbo build
D16Y8 turbo build
Hello everyone. I have just become the lucky owner of a 1997 Honda Del Sol Si with a D16Y8 and want to turbocharger it. My goal is around 350hp. I have tried to find as many D16Y8 turbo forums as I could so hopefully we don't have to go over old information. From what I understand I need a Z6 crankshaft (do I need Z6 bearings?), ARP head bolts, an upgraded fuel pump (I found a Walbro 255LPH), larger fuel injectors (any recommendations?), Forged rods and piston heads (I found Wiseco pistons and eagle rods from real street performance), and then the turbo kit (a CX racing turbo kit with T3/T4 hybrid turbo from Andy's auto sports), I will also be getting a Yonaka motorsports stage 3 clutch, is there anything I am missing? Thank you in advance!
Re: D16Y8 turbo build
Man U FTW
Buy a real turbo kit and a name brand clutch or you'll regret it later when they fail.
Go-Autoworks is a budget friendly option for quality setups
Competition Clutch is what i'd suggest for the clutch side of things, not Yonaka - never heard of them
Yonaka Clutch - doesn't seem like a quality product IMO
Okay. So I am going to scrap the idea of a cheapie turbo kit and save up a bit more for a Go-Autoworks kit. Same with the clutch. As far as the actual rebuild goes I'm going have it done by a shop since I don't have the area to do it or some needed tools. For injectors I was curious as to any suggestions for size. Obviously something like 1000cc would be to big for a goal of 350hp so What size should I upgrade to? And if anyone could recommend a brand I would appreciate it. Then there is the issue of tuning. The only ECUs I have found are for OBD1 (93-95) and mine is a 97. Does anyone know a solution? Thanks again guys, I really appreciate the help!
Edit: I found a set of 550cc injectors from Go-Autoworks, would this be good for my set up?
Man U FTW
Deatschwerks 750cc Injectors
ECU: Since you're OBD2a, you need a jumper harness from OBD2a to OBD1 and will then run either a P06 or P28 ECU socketed for Hondata/ Neptune/ Crome , etc. (links below)
OBD2a to OBD1 Jumper Harness - Xenocron
Chipped P28 ECU - Xenocron
Crome Pro (Cheap tuning option) - Xenocron
Retired Moderator
Lets not forget motor mounts..
20 year old mounts will turn to jelly with that much power.
Yung grasshoppa, ye will learn the weakest link in your set up really quick until youve replaced almost everything.
Your first and most important thing is have suspension components checked and replaced if they are out of service condition. Brakes as well. adding 3X the power it was designed for means your going to have to make sure the car is safe for you and others on the road.
Also have a different car for when something breaks (and it will) so you can get to work while its being repaired.
550cc injectors would almost cut it, but i'd probably go for 720-880cc on gasoline and 1000cc's for e85. Injector Calculator
What suspension components should I check? I was considering going through and just replacing all the bushings, I figured after 20 years they are probably going to need it. And I have a 06 impreza as a back up car. I know I will need it eventually haha.
