Obd2 emissions
Old Aug 21, 2016 | 10:34 AM
junior_tm's Avatar
Default Obd2 emissions
This goes to all my fellow obd2 owners that are turboed using obd1 Ecu!
What do you guys do when it's time to get emissions done? I've searched and asked a few members but no prevail. I've read some people say keep your stock Ecu? How can I do that if I'm running let's say 15psi?
Thank you in advance
Old Aug 22, 2016 | 04:45 PM
Geis's Avatar
Default Re: Obd2 emissions
Either convert it back to stock (pain in the ***) or pay someone to forge it. The latter is what I did
Old Aug 22, 2016 | 04:59 PM
boosted94gsr's Avatar
Just put the stock obd2 ecu, stock injectors and stock map sensor back in and stay out of boost 100% while you baby it to the emissions test.
Old Aug 22, 2016 | 05:08 PM
wantboost's Avatar
Who is Mr Robot?
Do the above but pull the waste gate spring or a charge pipe and drive it until the readiness checks are completed. Get it emissioned then swap everything back out.
Old Aug 23, 2016 | 11:37 AM
junior_tm's Avatar
Ok when you take the Ecu and put it back do you have to drive that 50 miles or so they say? Thank you
Old Aug 23, 2016 | 12:33 PM
Dark_Teg's Avatar
Dude, just talk to a few car guys someone will know a guy that will hook you up for a fee.
Old Aug 23, 2016 | 03:44 PM
the_unknown's Avatar
GDD Lonely Krew
So when the smog guy pops his hood and sees the turbo kit there, what do you guys think hes going to say? Oh well you have pulled your WG spring and you're not making any boost, but it's cool you pass because you're a cool guy..... No.
Nothing short of putting everything back to stock will get you by a smog check, unless you know someone. But hookup smogs are not cheap like they used to be. CA has been cracking down on bad smog stations and they are much less willing to help people out these days. Dont be surprised if someone asks for several hundred bucks to have this done as it is a big risk for a business owner. They will check to be sure all your emissions equipment items are in place and with a turbo setup that is basically impossible, unless you have a very rare CARB certified kit which if I am not mistaken hasnt been produced in years. It is the pain we go through for the privilege of living in CA. Buy a newer car and you only have to make sure there are no CELs, they dont need to do a full rolling road test on 2006 and newer cars I think? Someone correct me i am too lazy to research...
Old Aug 23, 2016 | 04:36 PM
wantboost's Avatar
Who is Mr Robot?
He lIves in atlanta. We don't have any of that CARB bullshit here so no visual inspections.
b16bri
Jun 30, 2010 08:10 PM
GsrIntegra789
Mar 20, 2009 01:35 PM
SOHC_me
Oct 16, 2007 11:48 AM
respectblades
Jan 28, 2005 01:40 PM
shadykit
Sep 19, 2004 04:02 PM
