Lsvtec boosted help camshaft selection
Old May 29, 2016 | 12:02 AM
dcsports's Avatar
Default Lsvtec boosted help camshaft selection
What camshaft a should I run currently running stock b16 cams on b16 head. Looking for most power and reliable.
Old May 29, 2016 | 01:44 AM
cruizinmax's Avatar
Default Re: Lsvtec boosted help camshaft selection
Need more information. Goals, turbo ect.
Old May 29, 2016 | 07:54 AM
dcsports's Avatar
Built bottom end . B16 head stock for now will be upgrading Springs and retainers. Turbo kit is an old school inlinepro log manifold t3/t4oe turbo. 750cc rc injectors . Really looking to get 500 to 600 whp
Old May 29, 2016 | 08:09 AM
ls joker's Avatar
Loved
Too get 500-600whp you will need a better turbo for starters. Second, camshafts performance may be affected due to the log manifold. Causing backpressure issues, if you went to large.
And make sure whatever springs and retainers you get will be adequate for your decision on cams. Also bigger injectors
Old May 29, 2016 | 08:19 AM
TheShodan's Avatar
Moderator
Correct. The springs and retainers need to have the correct spring Seat pressure to work with the camshaft you plan to use. So, it is better for you to choose the camshafts first then choose the valve train to match with those camshafts, versus the other way around.
The housings you listed could hold a variety of turbocharger wheels. If you're running the 46,50,57, or 60 "trim" versions, there's no way your power goals will be meet regardless of aftermarket or OEM .camshafts.
Please also give specifications of your "built" engine. Static compression, bore, stroke, etcetera.that makes a difference as well. .
Again, don't be lazy about typing. . BE SPECIFIC. If you know nothing about your own engine, how do you expect us to help? Be a part of your own process, please
Old May 29, 2016 | 08:43 AM
drmix's Avatar
Youll need bigger injectors. Im running the same injectors and am just about maxed out at 427whp. What fuel will you be using?
Old May 29, 2016 | 03:34 PM
dcsports's Avatar
Sorry guys will more specific in my next post I posted from my phone pain in the *** to type on
Old May 29, 2016 | 03:35 PM
dcsports's Avatar
What injectors you guys recommend for the power I want.
Old May 29, 2016 | 04:03 PM
boosted94gsr's Avatar
What fuel are you using? You won't get anywhere near your power goal on 93 octane pump gas and your fuel system will need some upgrades if you go e85. Like ls joker said an equal length manifold and bigger turbo will probably be needed too.
Old May 29, 2016 | 06:18 PM
duugle's Avatar
I made ~540whp on 93 octane with:
LS/VTEC (b18a1 block/b18c5 head) 2 liter 9.7:1 compression
Full GSC valvetrain with GSC T1 cams
Ramhorn manifold
T4 60-1 at 17psi
Edlebrock Victor X
ID1000 injectors/340LPH fuel pump/58 PSI fuel pressure
Tuned by Matt Shue
Sounds pretty good at idle as well:
Old May 29, 2016 | 06:20 PM
dcsports's Avatar
That sounds bad ***
Old May 29, 2016 | 06:27 PM
TheShodan's Avatar
Moderator
It also seems like a dyno with too high a rating for that turbo st that boost pressure with that fuel.. they were being kind to you.
Old May 29, 2016 | 07:39 PM
Ramhorn manifold
T4 60-1 at 17psi
Edlebrock Victor X
Tuned by Matt Shue
I should have been more clear. I wasn't saying you can't make 500+whp on 93 octane, I was trying to point out that you need a much more efficient setup to do it. Op probably needs better cams, manifold, turbo, & injectors to get to his goal. Your setup is obviously an effective setup without any restrictions.
Old May 30, 2016 | 05:21 AM
ls joker's Avatar
Loved
I think thats the guy with the 85mm ls/vtec.
To OP, its not that you cant make 500whp on 93 octane. Its the point that you should want to due to the more likely hood of detenation
Old May 31, 2016 | 05:20 AM
LightningTeg's Avatar
Community Builder
Reliability is more on the install / tune then anything. But OEM ITR cams come to mind. Drop in, make jam
Old May 31, 2016 | 08:33 PM
dcsports's Avatar
B18b1 81.5mm 9.5:1 wiseco pistons inlinepro rods with clevite bearings or rods and mains. Also with cnc werx css block guard. Stock ls crank. B16 head is stock except slunk2 manifold and 70mm throttle body. For fuel I have a walboro 450LPH e85 fuel pump . I deffenetly plan on upgrading my manifold to something better and also now plan on some bigger injectors
Old Jun 1, 2016 | 03:02 AM
TheShodan's Avatar
Moderator
No need to change intake manifold. You're going after the wrong parts
Old Jun 1, 2016 | 04:06 AM
extremeracer's Avatar
As mentioned earlier you would need a better turbo to reach your power goals. Something with minimum 60lb/min flow rating in order to get ~550whp.
If running E85 you'll be able to push more hp out of the turbo than 93 for example.
If you go with a 60 - 65 lb/min turbo, then ITR/CTR/Skunk2 Tuner 1/GSC T1 cams should all get you to the power range you targeting. Another thing mentioned earlier is that with the more aggressive cam profiles, log manifolds start imposing problems with backpressure and flow reversion - so a nice tubular turbo manifold needs to compliment the cam and turbo combination.
Old Jun 2, 2016 | 11:49 AM
dcsports's Avatar
I am currently looking at a klm top Mount manifold anyone know about there manifolds any good?
Old Jun 2, 2016 | 12:32 PM
TheShodan's Avatar
Moderator
Don't need a top mount for 500-600whp. May look cool, but slows any response for street use.
I'm actually kinda glad I've seen that fad sort of fade away a little.
Old Jun 2, 2016 | 02:09 PM
Geis's Avatar
But there's always your 'favorite' manifold...you know, spa top mount
Old Jun 2, 2016 | 05:11 PM
TheShodan's Avatar
Moderator
Don't remind me.
Old Jun 2, 2016 | 11:01 PM
MetalfaceEh3's Avatar
Up
OoAoO
Jan 6, 2014 07:29 AM
forryk
Dec 23, 2013 08:47 AM
JHipps
Engine Management and Tuning
Sep 30, 2013 06:53 PM
Navy_CRX
Jan 30, 2009 08:39 PM
joethejoeman
Jul 24, 2007 08:54 PM
