Help! What turbo will i get.
Hey guys! I will be starting to build my turbo engine soon. But before anything i would like to ask for your help on what turbo should i get and also feedback on the parts that im planning to use. My goal is around 550-600whp. Fuel will be on 100octane pump gas.
Turbo:
Borg s366sxe t4 .88 or precision-6266-ball bearing gen2
Wastegate turbosmart 60mm
Blowoff turbo smart raceport
Precision 750hp intercooler
Head:
Ferrea comp valves
Ferrea turbo valve springs
Ferrea valve guides
Ferrea valve keepers
Skunk2 pro1 camshafts
Intake manifold victor-x
Throttle body 70mm
Injectors ID 1300cc
Fuel pump walbro 450cc
GSR or Type-R head
Block:
sleeved 84x89mm
Arias 10.5:1 pistons
Eagle rods or pauter rods
Ecu
Hondata s300 v3
Turbo:
Head:
Ferrea comp valves
Ferrea valve guides
Throttle body 70mm
Injectors ID 1300cc
GSR or Type-R head
Block:
sleeved 84x89mm
Ecu
Hondata s300 v3
Re: Help! What turbo will i get.
I hate precision, so I'm going to say stay far far away.
S366 sounds like a winner (theyre 575$ shipped for the shelf one on ebay)
Man U FTW
Borg Warner S364.5 S300SX3 FMW S300 64.5/68 Billet 64.5 - AGP Turbochargers, Inc. Store
Borg Warner here as well. I used to run an S256 and it was a great little turbo ...and its still going strong 40k+ miles later
There are a lot of turbine options to pick from
Moderator
There are a LOT of choices for that range of power that's efficient for under 2.4 litres. What he's looking at is just huge. With the turbine housing even larger.
I would easily go smaller. Not as small as a S256, but something in the 58lbs/min-70lbs/min range. No more.
Man U FTW
This might be more size appropriate from the BW lineup
Borg Warner / AGP S261_RS Turbocharger - AGP Turbochargers, Inc. Store
