Boost drop question
Old Jun 13, 2016 | 08:29 PM
cr-vette's Avatar
Default Boost drop question
So I just a question and looking to get a little insight. I got my b16 Dyno tuned not to long I'm noticing boost drop in the top end. It's just a eBay t3 50 trim nothing special. It will hit 13psi at 7800rpm then proceed to drop to 10psi at 9500rpm. Wondering if anyone else have a experience with boost drop off on a 50 trim? I believe I'm out of its efficiency range.
Old Jun 13, 2016 | 08:35 PM
2kdrift's Avatar
Default Re: Boost drop question
are you using a boost solenoid?
just so you know an ebay 50 trim does not equal a true 50 trim, they havent figured out how to calculate trim sizes so a 50 trim usually means its a 50mm wheel when dealing with ebay turbos
Old Jun 13, 2016 | 08:40 PM
cr-vette's Avatar
Yes 2 different manual boost controllers and tons of different wastegate spring combos I can achieve a higher spike but it drops regardless
Old Jun 14, 2016 | 05:10 AM
BoostAndBoobs's Avatar
Im no expert on turbos by any means, but maybe your turbo is choking.
Old Jun 14, 2016 | 06:27 AM
TheShodan's Avatar
Moderator
Going right back to 2kdrift's valid argument
yessewey
Feb 19, 2010 08:50 AM
typesnick
Sep 15, 2007 04:29 PM
96vtecI4
Mar 22, 2007 05:31 PM
Metal Typhoon
Jun 9, 2006 11:55 PM
onemoreday21
Nov 29, 2005 05:11 AM
