Ebay catch can's vs everything else
Old Sep 1, 2016 | 10:19 AM
deucedeuceEK's Avatar
Default Ebay catch can's vs everything else
I've been looking at buying a catch can soon. Something such as what FCS or BWR sells, but I just found out that they now have china made catch can's that look similar. I do realize that there is not really much to a catch can in general. I am just curious if this is one of those times where I could cheap out a little bit and not regret it? Are the cheap ones even baffled?
Link to what im talking about:
http://www.ebay.com/itm/272049071055?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Sep 1, 2016 | 12:10 PM
Dark_Teg's Avatar
Default Re: Ebay catch can's vs everything else
I would run that catch can. Mine was made by Turbo Elements and was about 150 bux but the can you posted looks legit enough. I think most of the big brand named cans are way overpriced.
Old Sep 1, 2016 | 12:36 PM
2kdrift's Avatar
agreed for the most part here, although you do get what you pay for. Unless it specifically says that its baffled I would assume that it is not. Welds,baffles, fittings etc will be lower quality in general when going with a knock off.
Personally I am happy with BNR fittings I would not hesitate to buy one of these from him if I was going to upgrade (I have the smaller can version), catch cans pretty much last forever so its kind of a one shot deal might be more expensive up front but I think you would be happier in the long run with a quality piece.
Old Sep 1, 2016 | 01:27 PM
TheShodan's Avatar
Moderator
I agree with this.. I also have the B&R catch can system, but, slightly customized/modified to more my liking.
This is one of those items in which the way the system is put together is more important than the full sum of the parts used. So, sure, you can use lesser expensive cans to do what toy need to do, but regardless of full cost, if it's not done properly, you have performed all for naught anyway.
There are several ways to make the system for turbo retrofits like ours, so that is where the cost variance can change.
This a case where you won't hear me bitch about eBay/knock-off stuff so much. The can itself is only one part of the system
Old Sep 1, 2016 | 04:44 PM
slomofo's Avatar
GDD Member
Serious question....
What does a catch can do?
Old Sep 1, 2016 | 05:23 PM
TheShodan's Avatar
Moderator
Best explanation
Old Sep 1, 2016 | 07:46 PM
Ronnie Cason's Avatar
me personally im planning on going this route
GO-AUTOWORKS Catchcan (S) Valve Cover Combo
Old Sep 1, 2016 | 08:37 PM
TheShodan's Avatar
Moderator
Sure...why not. Of course, I'm not a fan of the whole valve cover vent phenom..But to each
Old Sep 1, 2016 | 09:32 PM
im doing it to this valve cover as well
Old Sep 1, 2016 | 11:56 PM
slomofo's Avatar
GDD Member
Originally Posted by TheShodan
Best explanation
I can't view video.
Cliffs?
Old Sep 2, 2016 | 11:50 AM
2kdrift's Avatar
try using a PC it works fine for me, or search you tube
heres the link "https://www.youtube.com/watch?v=PWz6vCnJ4CA"
Old Sep 2, 2016 | 05:26 PM
Anyone have a picture of this Neukin catch can in a car? It would be nice to not have to relocate my battery.
Oil Catch Can
Old Sep 2, 2016 | 06:09 PM
2kdrift's Avatar
neukin is no longer is business so you can scratch that off the list. I think go autoworks was working on something that did not reloacte battery. or even better just get a standard 2 port catch can that most of us use, there is not need for such large ones as you are looking at
Old Sep 4, 2016 | 05:27 AM
blackeg's Avatar
its a bit older of a pic but thats my setup. -12 off the valve cover to a home made catch can. i basically welded a box and some -12 threaded nipples to it. there is a baffle plate inside toward the top. I used to run the back of the block fittings but once i cranked the power to 500 or a bit over it would push oil and fill the can like every 2 pulls at the track. no issues like that from the valve cover.
whatever one you choose dont use one with the drainback. the oil in the can gets mixed with condensation producing that chocolate milk look i wouldnt want that in my motor
Old Sep 6, 2016 | 11:11 AM
Almost went with the fcs catch can, but they raised the price of it on thier website of course when I went to purchase. So I ended up buying one from KLM for a good price.
Honda4life777
Jun 1, 2009 09:23 PM
20civic03si
Aug 31, 2007 04:01 AM
vtec-adykt
Jan 27, 2007 03:08 AM
spooncivic1
Jul 4, 2006 02:45 PM
h22a193
Nov 7, 2005 05:05 PM
