Having an issue with my heatwrap..
Old Jun 21, 2016 | 02:57 PM
blackeg's Avatar
Default Having an issue with my heatwrap..
So I have fiberglass from the heatwrap on my manifold and downpipe getting all over in my engine bay. Is there a way to keep it from falling apart and getting all over? The wrap has only been on the car for a year or around 1500 miles...
Old Jun 22, 2016 | 09:03 AM
SpeedRacerEX-R's Avatar
Default Re: Having an issue with my heatwrap..
Did you put the header wrap spray on it?
Old Jun 22, 2016 | 09:17 AM
Aradin's Avatar
Premium Member
What brand wrap did you use? The cheap chinese wrap falls apart easily. Never had an issue with the DEI stuff unless it was directly rubbing on something. I never use the spray either.
Old Jun 22, 2016 | 11:26 AM
TheShodan's Avatar
Moderator
There's a "spray"? Made of what, in order to do what?.....What kind of sorcery is this?
Old Jun 22, 2016 | 05:24 PM
blackeg's Avatar
I didnt spray it. Honestly i didnt know there was a spray ive never had to use it over the years. This is the first real time ive had an issue. I just looked at the package and its definitely some cheap crap i got at autozone...Guess i dug my own grave on that one
Old Jun 22, 2016 | 07:02 PM
2kdrift's Avatar
Design Engineering Hi-Temp Silicone Coating Spray - Black 010301: Advance Auto Parts
Old Jun 22, 2016 | 07:36 PM
TheShodan's Avatar
Moderator
Interesting. Or I can dip mine in water like I've always done
Old Jun 22, 2016 | 09:41 PM
2kdrift's Avatar
I beleive you would still dip in water...the coating is similar to hi temp paint.
I dont have experience with any of this as I use the "lava" style
Old Jun 23, 2016 | 03:26 AM
TheShodan's Avatar
Moderator
I gotcha
Old Jun 23, 2016 | 07:26 AM
wantboost's Avatar
Who is Mr Robot?
I only use the DEI volcanic rock stuff, I've never had it fall apart on any car I've put it on. Don't have to soak it for application or spray it, plus there is that whole you don't itch for days factor when you wrap something.
The fiberglass stuff and especially the cheaper versions almost always start to fail and fray like you are experiencing.
Old Jun 24, 2016 | 02:58 AM
LightningTeg's Avatar
Community Builder
I've used both alot.
The fiberglass you should dip in water before applying to surface so when it dries it contracts and gets nice and tight on the pipe. Then you can spray it with the high temp silicone stuff to seal it / help keep it from fraying.
The synthetic volcanic stuff is much simpler. You just put it on lol. Its much kinder to the skin, no water or spray necessary.
Both are considered one time use (you put it on the pipe and leave it). The fiberglass will fall apart easier and right after you install it you will have fiberglass fibers all over near it and your engine bay. The volcanic stuff is worth the extra cash.
Old Jun 26, 2016 | 07:00 PM
B and B's Avatar
Loved
Community Favorite
I've also used the VHT ceramic spray as a sealant and it lasted well, till something rubbed (DP to rad,) then it was severed. (used the silver color)
Old Jun 27, 2016 | 01:51 PM
dpetro1's Avatar
i just wrapped my downpipe with the DEI titanium wrap this weekend. very easy to use, no water or spray needed
Old Jun 29, 2016 | 04:49 AM
rice a roni's Avatar
I have the lava wrap on for over a year now. Seems to have gotten brittle and started ripping/falling apart when I took my manifold off.
Its a nice product. Not sure if I would buy again.
jdmcx
Paint and Body
Dec 9, 2011 04:16 AM
tepid1
Paint and Body
10
Mar 15, 2010 07:07 PM
577HondaPrelude
19
Apr 1, 2006 06:45 PM
Natural Aspirations
Welding / Fabrication
Feb 1, 2005 02:21 PM
phiberoptik
Feb 26, 2004 11:38 AM
