Cometic with stock block?
Old Jun 19, 2002 | 02:34 PM
eddie1681's Avatar
New User
Default Cometic with stock block?
Can the Cometic headgasket with an stock block? I have heard that you need the block to be O-ringed or step when using an cooper headgasket.
Is anyone using it on their stock block?
btw: I am using it on my B16A for turbo how thick should I use?
Thanks
Old Jun 19, 2002 | 02:44 PM
schwett's Avatar
New User
Default Re: Cometic with stock block? (b20z)
the cometic head gaskets are not copper. call them up to get the whole scoop, but i'd be shocked if they coudldn't be used with a stock block. in fact, i found out after the fact that their turbo gaskets are not recommended for use with a step-deck block. (the fire ring plus the step deck will give you a great seal for combustion, but the rest of the head might leak - fingers crossed )
Thanks
Old Jun 19, 2002 | 09:39 PM
eddie1681's Avatar
New User
ohic, I will do more research
Thanks
demian22
Feb 28, 2008 10:34 AM
cotten_itr
Aug 19, 2007 01:21 PM
marksturboek
Apr 23, 2006 03:02 PM
bigapple427
Jul 12, 2005 10:15 AM
