License Plate blocking air to FMIC??
hey turbo guys do you have any expirience w/ this
does your license plate cause any loss to your IC efficiency, from blocking some of the air flow,..?
don't flame just an honest Q.
1 Post
Re: License Plate blocking air to FMIC?? (mey_xanng)
Easy! Two L-shaped pieces of aluminium. Then basically drilled holes and mounted them onto the license plate with nuts'n'bolts.. then mounted the other end of the pieces of aluminium to the inside of the bumper on the top. I hope I explained it in a way that you can understand Just look closely at the pic, I think you'll be able to figure out where I mounted it onto the bumper
Re: License Plate blocking air to FMIC?? (turbopanda)
oh Ok, like one end of the aluminum 'L' is on the plate the other on the car, how do you mount the alum. onto the car, by drilling and skrews.. or... adhesive...
offsubject
hey are you really in Thailand right now?
[Modified by mey_xanng, 6:33 AM 6/17/2002]
offsubject
No. The air flow is going to just go straight around the plate, and go right through the IC anyway's.
This would only be a problem if you had a IC only as big as your plate, and the plate was right infront blocking the air flow.
here's mine...
here's mine...
Re: License Plate blocking air to FMIC?? (dmotoguy)
that is one CLEAN civic... nice job, did you just drill holes in your bumper?
My bumper is jacked(lip broke off, chipped and cracked here and there) so I didn't really care about drilling into it.
1 Post
offsubject - hey are you really in Thailand right now?
turbopanda:
thx
hey how are the prices of performance parts in Thailand compared to the US?
my cousin went to Thailand last year, and he said everythings extremely cheap
thx
1 Post
Some things are cheap.. some things are expensive..
there's a good second-hand market here, and you can usually find a lot of bargains on aftermarket performance parts.
although defi meters over here still cost the same, if not a "little" bit cheaper than you guys over in the US. really depends on what you're looking for..
DBigman
04-17-2008 08:01 PM
ex voto
22
06-10-2005 11:45 PM
