boost gauge install?
Old Jun 18, 2002 | 09:15 PM
aesthetics82's Avatar
Default boost gauge install?
i have a greddy boost gauge and profec b....i have all the vacuum lines connected but i dont know how to hook up the electrical...for the gauge...one line is ground, one for 12V power source, one for ignition and one for a light source....for the profec b, one is a ground and one is a 12V power source while the ignition is on. i have the honda manual but i dont understand the wiring diagrams...can some one please help me out..thanks
Old Jun 18, 2002 | 10:02 PM
Anthony K's Avatar
New User
Default Re: boost gauge install? (aesthetics82)
Power? I go to one of the wires entering the car stereo.
Old Jun 18, 2002 | 11:24 PM
TheIntegraGuy's Avatar
Default Re: boost gauge install? (Anthony K)
cig lighter...ghetto..but it does the trick..I think everyone can agree with me..hehe
Old Jun 19, 2002 | 11:54 AM
Etylorcen's Avatar
Default Re: boost gauge install? (J-MiGiRL702)
Off the stereo deck is where I got my power.
Old Jun 19, 2002 | 12:03 PM
zojirushi's Avatar
Default Re: boost gauge install? (Etylorcen)
Can you use the same source for the 12 v and the ignition? I'm also confused about this matter. Someone told me to use the cigarrette lighter for the ignition. Now, where do i find a constant 12 v source?
Old Jun 19, 2002 | 01:41 PM
intekragsr's Avatar
I powered mine off the boost controller since its power is hooked up to the ecu.
Old Jun 19, 2002 | 03:32 PM
zojirushi's Avatar
Default Re: boost gauge install? (intekragsr)
anyone else have any insight?? Where do i find a constant 12 v source... and what the hells the point of it?
Old Dec 26, 2002 | 11:09 AM
TheHater
Guest
Posts: n/a
Default Re: boost gauge install? (zojirushi)
crusie control red and white wires
Old Dec 26, 2002 | 11:26 AM
CzanSOHC's Avatar
Default Re: boost gauge install? (BOOSTINSI)
off the fuse box...spice in w/ the "acc" FUSE.
Old Dec 26, 2002 | 11:28 AM
rbf351's Avatar
cruise control is the best place especially on a civic since it's right near the pillar
Old Dec 26, 2002 | 12:05 PM
arjusmc's Avatar
do you have a stock stereo or do you have an aftermarket one?
Old Dec 26, 2002 | 02:22 PM
lilxvtecxpwr's Avatar
Default Re: boost gauge install? (arjusmc)
pull out your owners manual. just plug it into a fuse in the fuse box. for light source, wire it into the fuse for "instrument lights". for ignition, plug the wire into the radio fuse. use the radio fuse for 12v too. its really simple.
Old Dec 26, 2002 | 02:26 PM
TurboTegB18c's Avatar
Default Re: boost gauge install? (lilxvtecxpwr)
There should be plugs near the fuse box that have spades sticking out of them. All you need is a test light to find out which one is 12v constant, 12v ignition? there is like 5 of slots there and u can just get a female spade and plug it there. Hope you understand what i mean. Paul
Old Dec 26, 2002 | 05:14 PM
ImAcracker's Avatar
Loved
i have a greddy boost gauge and profec b....i have all the vacuum lines connected but i dont know how to hook up the electrical...for the gauge...one line is ground, one for 12V power source, one for ignition and one for a light source....for the profec b, one is a ground and one is a 12V power source while the ignition is on. i have the honda manual but i dont understand the wiring diagrams...can some one please help me out..thanks <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/h-emblem4.gif" BORDER="0">
OK this is what you need to do. Go buy a test light (really cheap). Connect the ground wire of the test light to the body of the car. Then with the key turned off start probing wiring with the test light until the test light turns on. That will be your constant 12v. Connect that to your 12v power source wire. Then with the key turned on start probing wires until the light comes on again. Now to make sure that this isnt a constant 12v turn the key of and make sure the light turns off. If so this will be connected to the ignition wire. OK? got it so far? Now for the light source turn your parking lights on and then start probing again until the light comes on. Again to make sure this isnt a constant 12v turn the lights off and make sure the test light turns off. This will be connected to your light source wire.
Hope this makes sense. Good luck.
EDIT: And oh yeah your ground wire connect to the body of the car somewhere.
[Modified by ImAcracker, 2:15 AM 12/27/2002]
Natural Aspirations
Engine Management and Tuning
Sep 6, 2012 05:27 AM
blazin99si
Jul 9, 2009 10:43 AM
da_ska
May 31, 2009 07:24 AM
SuperpooV
Dec 3, 2003 05:05 PM
zojirushi
May 6, 2002 08:13 AM
