what turbo to use on b16
Old Jun 20, 2002 | 05:44 AM
my91civic's Avatar
Default what turbo to use on b16
just wondering what turbo you guys are using on your b16. been reading alot of posts, it seems most people are running t3/t04e. just wonder is this the best choice for a street car, and if so what a/r and trim. did a search and came up with .63 a/r on turbine housing stage III and .50 a/r on compressor housing with 50 trim. just wanted some opinions please, this is the last thing left to buy for my kit and the most difficult part to pick. TIA
Old Jun 20, 2002 | 06:18 AM
ArizonaTurbo's Avatar
Default Re: what turbo to use on b16 (my91civic)
T3/T04E
.63 A/R Turbine Housing
Stage III Turbine
.60 A/R Compressor Housing
57 Trim Compressor
Garrett makes this exact turbo and they are pretty inexpensive.
Old Jun 20, 2002 | 10:22 AM
easy jesus_151's Avatar
Default Re: what turbo to use on b16 (TurbochargedSER)
I would like to know also. Is there anymore suggestions?
Thanks
Old Jun 20, 2002 | 10:33 AM
paulzy's Avatar
T3/T04E
Stage III Turbine
57 Trim Compressor
ditto....I can get for you for dirt cheap
Old Jun 20, 2002 | 10:44 AM
BoOsTeD_eK's Avatar
Default Re: what turbo to use on b16 (Slow_ass_4dr)
this is the groupbuy I am setting up...all we need is 10 people..well 9..since I am gettign one myself....cut off will be 7/15/02
ok guys...I called again and they gave me the guy in charge since they understand that I am serious about the group buy and the guy was saying that they love selling bulk. I told him we were mainly honda guys with prepped engines and were lookign at a max of around 450HP. So he told me I should change the specs up a little to provide more performance.
We now have this turbo:
57 trim
.60 A/R compressor
.63 or .48 A/R on the turbine (depending if you have a 1.6L or 1.8L and above)
Compressor outlet diameter is 2 inches while while the turbine is a standard T3 2.75 inlet with a 4 bolt discharge. Flanges are available for an extra $15
Best of all PRICES HAVE REMAINED THE SAME $550 with shipping being around $20 per turbo...which will most likely be sent out straight from the distributor.
Hope this comes as good news to you all.
[Modified by BoOsTeD_eK, 7:45 PM 6/20/2002]
Old Jun 20, 2002 | 12:10 PM
Mr. Vapor's Avatar
Default Re: what turbo to use on b16 (BoOsTeD_eK)
i run a t3/to4e .63ar with a 54 trim
take a BIT longer to spool, but man the top end..........its worth it
Old Jun 20, 2002 | 04:36 PM
Default Re: what turbo to use on b16 (NYb16)
bump
Old Jun 20, 2002 | 04:45 PM
LsTurbo91's Avatar
I dyno'ed 271whp/198tq with that turbo @ 11psi, stock b16.
Balor_Gr
Oct 6, 2012 03:33 AM
jdmcivicek
Jul 2, 2003 08:30 PM
B00STeD
Aug 21, 2002 03:59 PM
H23ludedude
Apr 9, 2002 09:57 PM
InfamousRS
Dec 16, 2001 01:47 AM
