AVCR install question
Old Jun 18, 2002 | 01:15 PM
311's Avatar
311
Default AVCR install question
I need help installing my avcr. i have the electrical connections taken care of, i just need help with the 2 sensors that you mount in the engine bay and the vacuum lines. any help would be appreciated.
311's Avatar
311
Default Re: AVCR install question (311)
sorry, i have a jdm b16 in a 92 hatch with a greddy 18g turbo kit.
Old Jun 18, 2002 | 02:30 PM
311's Avatar
311
bump
Old Jun 18, 2002 | 04:06 PM
VTC_CiViC's Avatar
What help do you need? One is a pressure sensor (the only one with 1 vacuum inlet), and the other squarish thing with the 2 vacuum nozzles is the solenoid.
Old Jun 18, 2002 | 04:14 PM
xci_ed6's Avatar
Default Re: AVCR install question (VTC_CiViC)
Plug the yellow wire end into the yellow connector
-repeat for white and red wires
--repeat at the TV with other end of wires
plug the two bladed one prong connector into the socket on the wall with two slots and a hole
finally connect the threaded plug with a sharp thing in the middle onto the threaded plug with a small hole in the middle and tighten.
-repeat with other end of wire at the wall.
-Dustin
Old Jun 18, 2002 | 04:19 PM
flip1199's Avatar
go on the apexi web site and look at the manual if you dont already have one. http://www.apexi-usa.com/productdocu..._savcr_ins.pdf look on page 42 i think
Old Jun 19, 2002 | 09:06 AM
311's Avatar
311
Default Re: AVCR install question (Autocratic_1st_Gen)
-Dustin
Old Jun 19, 2002 | 09:08 AM
311's Avatar
311
Default Re: AVCR install question (flip1199)
I have the instructions, I just dont undertsand them. i just want someone to tell me what vacuum lines go to/from the circular sensor thingy and what lines go to/from the box thingy
Old Jun 19, 2002 | 09:23 AM
VTC_CiViC's Avatar
You run 1 vacuum line from the round pressure sensor to any boost source (most people choose the FPR vacuum line). Then you run one vaccum line to the 'IN' port on the solenoid, and another vacuum line from the 'OUT' port to your wastegate actuator.
Old Jun 19, 2002 | 09:35 AM
311's Avatar
311
very helpful, and thats it>? thank you so much!
$amGD3
Audio / Security / Video
14
Jun 8, 2011 08:55 AM
lorenzookc
Jan 26, 2010 06:22 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
bengeeee
Aug 6, 2003 05:23 PM
RAS Motorsports
Jul 10, 2003 11:52 AM
