What are these parts? and where do they go?
http://www.imagestation.com/album/pi...?id=4291709447
Hey turbo gurus:
I'll be installing the kit this weekend, but I could use some detailed descriptions of what these items are and what they connect to etc. I'm curious on the vaccuum line thing where those clear plastic valves should connect at and also on the return metal pipe, which end welds to the oil pan.
I'm sorry I can't figure out how to post these things directly into the thread, maybe someone could do that? TIA!
Hey turbo gurus:
Re: What are these parts? and where do they go? (Teg4e)
Dude...I hope you aren't doing this yourself, this weekend, if you don't know what those pieces are yet, heh.
The first is the oil return, I believe. the second, I'm sure, is the fitting for the oil return. you're using AN-style fittings right? the third is the checkvalve rig. you hook up one end to the port for the MAP on the TB and then hook the MAP up to the other end to leak off boost so the ECU doesn't freak.
correct me if I'm wrong.
Re: What are these parts? and where do they go? (ion_four)
Yeah, I'm gonna try to do the install myself this weekend, and we'll just see how it goes.
Anyway, there's two brass fittings in there, one is straight through while the other is a 90 degree. I have a missing link, so do i still need this check valve system on my vacuum lines?
1st picture, from left to right
1. 90 degree elbow for turbo oil feed
2. 1/2" npt to some size hose adapter
3. piece of pipe? possibly for oil drain?
2nd picture, left to right
1. straight fitting for turbo oil feed
2. T3 oil drain flange, 1/2" npt w/gasket
3rd pic already has been explained and you don't need them anyway.
Re: What are these parts? and where do they go? (mplex2000)
pic1part1 and
pic2part2. ..those are self explanatory..get some ss line...
the oil return take pic2part3 and bolt it up to the turbo
take pic1part2 and threat that in the flange
take pic1part3 and use a clamp to come down to your pan.
then youre fucked u still need a fitting that gets welded to your pan..
hth!
Re: What are these parts? and where do they go? (Giuseppe)
So that metal pipe doesn't get directly welded to the oil pan?
u sure that you dont have another fitting lying around somewhere???
2point2
09-10-2005 09:33 AM
