Joining the darkside very soon :-)
Old Jun 17, 2002 | 01:39 PM
M.A.R.C.'s Avatar
Default Joining the darkside very soon :-)
Just wanna let everyone know I should be joining the darkside pretty soon. Possibly 3 weeks tops and maybe another week just to make sure everything's ok then do install.
This is my planned setup. Any suggestions would be appreciated. I still need a manifold that will definately work with AC... FL is hot
Turbo Kit:
Garrett T-25 Turbocharger
Starion Intercooler
Apex'i Twin Chamber Blow Off Valve
>TEC Wastegate Assembly (6psi)
>Custom Manifold <-- SUGGESTIONS?
>JC Whitney Charge Pipes
>Custom Downpipe
Fuel System & Tuning::
DSM 450cc Injectors
88-91 Injector Resistor Box
Apex'i V-AFC
255lph Walbro Intank Fuel Pump
>RC Injector wire clips
Electronics & Gauges:
Greddy Turbo Timer
Autometer Sport-Comp A/F Ratio Gauge
Autometer Sport-Comp Boost Gauge
Autometer Dual Gauge Pod
>NGK BCPR7ES-11 Spark Plugs
Miscellaneous:
>Oil-line Kit & Fittings
>Gaskets, Vaccum hoses, silcone hoses, coolant lines, etc
Everything without the > next to it I've already bought. The TEC w/g assembly is a necessity because the stock w/g spring is 12psi and I heard the only way to change this is to get a whole new assembly. I need suggestions on the manifold and what fittings to use for oil lines etc. And also the best way to route the coolant lines to the turbo. Thanks all.
Marc
Old Jun 17, 2002 | 01:46 PM
djdxm's Avatar
Default Re: Joining the darkside very soon :-) (CivicRyda2k)
Bahhh!. T25 baby turbo.. I hope you ment Y2k hehe j/k
Kickass Marc you were able to pull this together faster than I did, I think your car will be a fun ride. You better get out here I wanna ride in it. I love quick spool torque. Better bring yours out to Cali.. (i dont think mine will make it, probably blow up... )
-jay
Old Jun 17, 2002 | 02:02 PM
M.A.R.C.'s Avatar
Default Re: Joining the darkside very soon :-) (djdxm)
-jay
hehe... all good I'm only looking for a street performer/weekend track warrior. If I feel the need (well we all know i will)... I'll upgrade to a 16G (DSM T-25 = TD05H flange). VTC is running the 15g and he runs low 14's on street tires so I know the 16g would be good enough.
Old Jun 17, 2002 | 06:52 PM
M.A.R.C.'s Avatar
Ooooo my fuel pump came in the mail today . Any one got any suggestions? ANYONE?
Old Jun 17, 2002 | 08:50 PM
93LSivic's Avatar
I would suggest a bigger turbo. The T25 is my turbo's bitch
Old Jun 18, 2002 | 12:55 PM
M.A.R.C.'s Avatar
Default Re: Joining the darkside very soon :-) (93LSivic)
rofl... yah yah i know... but isn't a t-25 at 6psi pretty damn good for a street setup because of the quick spool. And I'm not planning on running much more than 10 at most on this turbo and at that level it still would be pretty efficient.
Old Jun 18, 2002 | 12:57 PM
T3EMSI's Avatar
HKS turbo manifold. you can find them new for like 280-320 depending where. They utilize the T25 flange and is ac compatible.
Old Jun 18, 2002 | 01:17 PM
M.A.R.C.'s Avatar
Default Re: Joining the darkside very soon :-) (T3EMSI)
yah I thought of that but DSM Garrett T-25's actually use a Mitsubishi flange. So they won't bolt up. I called HKS to verify this as well.
acman1
Mar 6, 2003 02:41 PM
M.A.R.C.
Aug 26, 2002 12:33 PM
M.A.R.C.
Jul 7, 2002 10:09 AM
M.A.R.C.
Jun 25, 2002 07:31 PM
genop
Jun 15, 2002 11:58 PM
