Strength of a Vacuum Source?
Old Jun 19, 2002 | 04:00 PM
95TegGSR's Avatar
Default Strength of a Vacuum Source?
I have a 1997 turbocharged LS motor; there is only one vacuum source on the intake manifold. If I T that off to 4 more ports using standard Ts, does that decrease the strength of the vacuum pull?
I need that vacuum source to tap into: a 3-bar GM map sensor, fuel pressure reg, and wastegate. I just want to make sure it will get the right amount of vacuum pull even though it is only coming from one source.
Old Jun 19, 2002 | 04:02 PM
Cramerox's Avatar
Default Re: Strength of a Vacuum Source? (95TegGSR)
and what vacuum source is that? what about the break booster. lots of people take vacuum of that and t it into 4
Old Jun 19, 2002 | 04:25 PM
95TegGSR's Avatar
Default Re: Strength of a Vacuum Source? (Cramerox)
It is the original vacuum source for the fuel pressure regulator. But does Ting it off into 4 decrease vacuum strength?
Old Jun 19, 2002 | 04:50 PM
GruvyTune's Avatar
New User
I tapped 4 ways. Its fine especially if you are tapping sensors which don't put any real drain on the vacuum since its all a closed system!
Old Jun 19, 2002 | 06:03 PM
tonydatyga's Avatar
Default Re: Strength of a Vacuum Source? (GruvyTune)
ding ding
Old Jun 19, 2002 | 06:07 PM
95TegGSR's Avatar
Default Re: Strength of a Vacuum Source? (tonydatyga)
Thanks for the info...
B18 CYA
Jul 16, 2004 11:20 PM
red_sir
Feb 4, 2003 06:50 PM
xci_ed6
Aug 10, 2002 05:35 PM
95TegGSR
Jun 19, 2002 06:09 PM
