Need advice on Boost Spike!!
Old Jun 18, 2002 | 01:23 PM
KekeK-18's Avatar
Default Need advice on Boost Spike!!
I have a t3/t4 hybrid with tial 35mm (9 psi spring) and profec B. When I gun it (with the boost controller off), the boost will spike to 15psi and settle back in 9psi. I use to connect the vacuum from wastegate (side) to the intake manifold and now I switch it to the charge pipe and the boost still spikes occasionally. Is my wastegate too small for my application? Any other thoughts?
Old Jun 18, 2002 | 01:26 PM
CovertFI's Avatar
Default Re: Need advice on Boost Spike!! (KekeK-18)
dont connect the vacumme part up. only use the boost
Old Jun 18, 2002 | 01:55 PM
KekeK-18's Avatar
Default Re: Need advice on Boost Spike!! (CovertFI)
what do you mean??
Old Jun 18, 2002 | 02:46 PM
CovertFI's Avatar
i did not know what i was doing when i first went turbo. i hooked up the wg wrong. unless you are using a boost controler made for an external wg you dont use the top part of the wg. disconnect it and see what happens.
Old Jun 18, 2002 | 02:51 PM
KekeK-18's Avatar
I have an EBC.
Old Jun 18, 2002 | 08:32 PM
KekeK-18's Avatar
Any one have a clue????
Old Jun 18, 2002 | 09:09 PM
highmilehatch's Avatar
From what I understand, profec b and external wastegate goes like this:
Black Box In - vacuum source on intake manifold
Black Box Out - top port of wastegate
Wastegate side port - vacuum source on intake manifold
Is this correct?
Old Jun 18, 2002 | 09:17 PM
KekeK-18's Avatar
Default Re: Need advice on Boost Spike!! (turboeg)
here is my configuration...
Black box in --- Manifold
Black box out-- top of the wastegate
(now)Side port of wastegate-- Charger pipe
(before) side of wastegate---- Manifold
Could it be my wastegate(35mm) is just not efficent enough?
Old Jun 18, 2002 | 09:24 PM
What happens when the boost controller is turned on?
Old Jun 18, 2002 | 09:28 PM
KekeK-18's Avatar
same thing, it will spike up a little, 3-4 psi and settle back down to whatever it should be.
Old Jun 18, 2002 | 09:37 PM
From what your describing, it SEEMS like your wastegate obviously isn't regulating the boost. However, if I were you I would disconnect the the profec b all together, run the top port open, and run the side to the intake manifold-correct me if I'm wrong. That way you'll be able to check if it has to do with the boost contoller. If boost holds steady at 9 psi then I'm assuming theres something wrong with your profec b.
turbo_d
Jun 5, 2022 06:46 PM
zach1288
Jul 8, 2010 02:39 PM
pv2dickman
May 27, 2005 05:59 PM
HybridKOOP
Aug 19, 2002 02:41 AM
JMinSi2000
Jun 18, 2002 10:12 PM
