Upgrade Fuel lines
Looking for information on upgrading the diameter of the factory fuel lines. At what point is the factory fuel line from the tank up to the fuel filter to small.
Thank you, My plans were just to remove the factory style filter system and to also change to a straight through fuel rail fitting. But is there a point at which the factory fuel rail becomes to small?
Ive heard somewhere around 325hp. But the aftermarket ones look so much nicer!!
yeah, he did, I think it was just a 1/4" NPT fitting to a hose connector...I may be wrong..
or you can just use a 1/4" to -6AN for the fuel rails and change the banjo fitting to the 12mmx1.25 with a -6 hose end..
k24egturbo
Oct 19, 2010 08:41 PM
OH_1fstgsr
May 3, 2010 03:27 PM
boomslang
Dec 5, 2002 10:36 AM
