fuel problems!!!!
Old Jun 17, 2002 | 09:28 PM
V8 BAIT's Avatar
Default fuel problems!!!!
here it is as brief as possible. my boosted hybrid crx has been running CRAZY rich since my turbo install. ive tried leaning it out with my vafc, tried running without my inline pump,replaced my fuel pressure reg,installed an msd,and even upped the boost just for the heck of it.i heard that normally when injectors go bad you run lean but haven't tested them yet.would it maybe be the FMU...? any suggestions will be appreciated cause im just plain sick of this 14 mile per gallon crap!
Old Jun 17, 2002 | 09:40 PM
V8 BAIT's Avatar
Default Re: fuel problems!!!! (v8bait)
almost forgot, my idle is rough with bad hesitation when you try to rev . its almost like it floods and the same thing happens occasionally when just driving at a steady rpm. it kind of loads up or bogs / hesitates .thats the best description of yhe problem i can give...
Old Jun 17, 2002 | 10:11 PM
93LSivic's Avatar
Sounds like the FMU is either installed wrong, or its stuck open. Check that out
Old Jun 17, 2002 | 10:16 PM
SlowB16's Avatar
Default Re: fuel problems!!!! (93LSivic)
I think I remember this topic awhile back and people said check the polarity on the inline pump...I dont think the FMU would cause a bad idle
Old Jun 18, 2002 | 03:45 PM
V8 BAIT's Avatar
how can i test whether or not the FMU is stuck.... should i just take it off temporarily and drive on really low boost to see if it runs leaner ?
Old Jun 18, 2002 | 03:53 PM
mike's Avatar
H-T Order of Merit
Take it apart and see if the metal cylinder slides in and out smoothly.
slowpokesi
Nov 6, 2004 04:14 PM
Andrew 825SM
Oct 19, 2004 09:00 AM
mikelcrx
Jul 6, 2002 10:20 PM
ludelvr
Jun 4, 2002 10:38 PM
integraracer94
May 19, 2002 09:12 PM
