ITR cams+ turbo=?
ITR cams+ turbo=?
Ok, im planing to fully build a b20vtec in the next year or so and boost it. i already have the b16 head bla bla etc etc.
heres the meat of my question.
Because the itr cams are more agressive, would this hurt performance for a turbo motor? i heard this somewhere.
Re: ITR cams+ turbo=? (KAMiN)
From what people say, it has more overlap and is more for all motor.... However, a guy that I nkow who's car makes 351 WHP @ 12 PSI with TYPE R CAMS, has no problems with them. Although, you will probably make more power with the GSR stock cams.
OH
can someone explain this to me?
the gsr cam is has a longer lift and duration than the b16 cam (there was an argument about this, its true right?)
why is that better than my stock b16 cams for turbo?
I couldn't find the spec on these. But from what I heard GSR cams are better for turbo. I have a b16 and planning to run GSR cams. Anyone wanna sell their stock GSR cams? Hit me up.
jason phan
jason phan
OH
1 Post
lift and duration = good; more air/fuel
overlap = not so good; unburnt air/fuel under pressure (compression) exits
Not sure why but having dealt w/ more gsr cams, they're relatively easy to dial-out most of the overlap w/ a set of adj. gears. Aggressive na usually means more lift and overlap and maybe a bit more duration. Basically, under boost you want more everything but the overlap, take it how you wish.
Re: ITR cams+ turbo=? (turbopanda)
I was told to go with itr cams too, they make more power, but like everyone said the overlap is not good, I decided on going with gsr's and stock cam gears
Re: ITR cams+ turbo=? (Jordo)
i hear at high high boost you want gsr cams!!!
just heard that somewhere
i heard it "somwhere"
anyone with PROOF of the gsr cams working better?
The power band of a motor gets "exaggerated" with a turbo. So if the power hits later All Motor it will hit later with a Turbo and when it does it will hit a **** load harder.
Re: ITR cams+ turbo=? (Rocket)
My old setup :
I had ITR intake cam only on my GS-R
Stock timing, stock internal, stock everything..
256WHP and 188 ft/lbs of torque at 6.5psi with no EBC when I dyno it...
drag 3 and Greddy SP..
find a stock GS-R with drag 3 then make the comparison...
ok
and nice numbers flamenco.
actually I kinda believe good things can happens out of bad things....
Re: ITR cams+ turbo=? (Flamenco-NA)
ok
can someone explain a little deeper, overlap to me?
im semi confused
im semi confused
Re: ITR cams+ turbo=? (HXMan)
Yep, thats basically it.
Overlap occurs on the exhaust stroke and into the next intake stroke. As the exhaust valve opens, the higher pressure exhaust begins to flow out. Taking advantage of this 'moving mass', we can go ahead and open the intake valve, while the exhaust is still open, to let that moving mass 'pull' in fresh charge before the piston begins descending.
When going turbo however, your already forcing the charge in there. Why would you want to force it out the exhaust?
Thats where the turbo/less overlap theme comes from.
Re: ITR cams+ turbo=? (EE_Chris)
ok, so that being true the best setup would be to have the overlap removed with cam gears and use a huge intake cam correct?
Well...ideally it would be nice to have custom cams that don't need to be adjusted. I am thinking a big intake and exhuast cam would be best.
itr intake and b16 exhaust should work fine then right?
1 Post
