conservative timing vs aggressive timing
Old Aug 31, 2002 | 04:24 PM
b00stedbyFastrax's Avatar
Default conservative timing vs aggressive timing
right now i am running a timing map for 92 octane gas at 22 psi. total timing at full boost is 18 degree. in anyone estimate, what would be the gain in using a timing map for c116 race fuel at this boost level with a air fuel ratio at 12.0-12.5. these maps are straight froom xs engineering for the power fc.
Old Aug 31, 2002 | 04:35 PM
VaporTrail's Avatar
New User
Default Re: conservative timing vs aggressive timing (BoostedbyFastrax)
on c16, I've used as much as 35 degrees total timing at around that boost level...
Old Aug 31, 2002 | 05:48 PM
Default Re: conservative timing vs aggressive timing (VaporTrail)
are you sure that is not a typo error- 35 deg .
Old Aug 31, 2002 | 06:05 PM
boosted3g's Avatar
at 30 psi in at 32 degrees of timing on C16.
Old Aug 31, 2002 | 06:09 PM
VaporTrail's Avatar
New User
yeap, I'm sure. That's total timing. 7.8:1 cr motor
Old Sep 1, 2002 | 06:30 AM
7.8:1 cr. that seem real enough. my timing map was for 9.0:1 CR with total timing at 26 deg.
Old Sep 1, 2002 | 06:35 AM
fast[R]'s Avatar
That is on pump gas right?
Old Sep 1, 2002 | 06:39 AM
Default Re: conservative timing vs aggressive timing (fast[R])
on vp c-16
fast2camciv
Sep 1, 2006 06:56 PM
spoolingb20
Apr 26, 2006 10:46 AM
CRXdan
Nov 26, 2004 09:49 PM
MintFlavored
Apr 22, 2004 02:59 AM
wrXtian
Mar 25, 2003 03:55 PM
