Code 41, primary oxygen sensor???
Old Aug 31, 2002 | 03:05 PM
speedymon's Avatar
Default Code 41, primary oxygen sensor???
Ok the good news is that i'm finally boosting. Finished the install today. bad news is that i'm throwing a code 41. I'm running open downpipe with just the primary plugged in. Car is a stock 96 obd2 gsr with basic dragIII kit. Any suggestions?
Old Aug 31, 2002 | 03:25 PM
Elite Hatch's Avatar
Default Re: Code 41, primary oxygen sensor??? (speedymon)
code 41 is an 02 related check code. It could be because you only have one 02 sensor hooked up.
Old Aug 31, 2002 | 03:32 PM
oscargsr's Avatar
Default Re: Code 41, primary oxygen sensor??? (Elite Hatch)
I also have a 96 gsr with a drag III. I am throwing the same code. How does your car drive under BOOST?
Old Aug 31, 2002 | 03:35 PM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (oscargsr)
I haven't tested the car yet. I'm scared.
Holy **** all Va peeps. Cool.
[Modified by speedymon, 7:56 PM 8/31/2002]
Old Aug 31, 2002 | 04:53 PM
PWRVTEC's Avatar
[QUOTE]
I posted on the other board........One more VA peep
Old Aug 31, 2002 | 05:45 PM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (PWRVTEC)
Cool beans ttt. Anyone else wanna chime in?
Old Sep 2, 2002 | 07:50 AM
PapaPark's Avatar
HT White Ops
you rang?
Old Sep 2, 2002 | 08:31 AM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (PapaPark)
:-P
Old Sep 10, 2002 | 05:02 AM
speedymon's Avatar
Anyone else with some ideas? I've reset the ecu and it still comes up. Both o2s are in the stock cat. WTF?
Old Sep 10, 2002 | 06:32 AM
GraphiteAccord's Avatar
i used to live in Newport News
Your GSR has two o2's, correct? if so, then apearently the 2nd one isn't getting any exhuast from you running open downpipe....
Old Sep 10, 2002 | 06:44 AM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (GraphiteAccord)
Uhhh no. I said that both O2s were in the cat and i'm still getting the code 41. Oh and Newport News sucks! hahahahah Va sucks!
Old Sep 10, 2002 | 11:37 AM
b_edson's Avatar
I had the same problem with my OBD2 GSR. Double check the wiring on the primary. When I looked, it turned out all 4 wires weren't connected.
Old Sep 10, 2002 | 11:58 AM
sgT's Avatar
sgT
Default Re: Code 41, primary oxygen sensor??? (b_edson)
41 is heater circuit. sometimes the black wires fall out of the plug
Old Sep 10, 2002 | 01:54 PM
dbman96's Avatar
New User
Default Re: Code 41, primary oxygen sensor??? (sgT)
hmm... what's an oxygen sensor??
Old Sep 10, 2002 | 02:23 PM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (dbman96)
I'll double check. I was sure i heard a click when i connected the primary O2 back in the harness. Maybe the downpipe burned it up.
Old Sep 10, 2002 | 02:24 PM
sgT's Avatar
sgT
the click is just the plug. the wires can come out of the plug
Old Sep 10, 2002 | 02:30 PM
speedymon's Avatar
Yeah i was thinking i was imagining things when i heard the click. I worked around the clock to put the turbo in all by myself. I was tired, hungry and dirty so i might not have hooked it up right. Oh well i'll check later.
Old Sep 10, 2002 | 03:37 PM
TurboInteg95's Avatar
On my car which is OBD1 I threw a code 41. I replaced the o2 with another one I had laying around and that solved the problem. I think what killed my o2 was the fact that when I installed my Hondata I missed a step that caused it to not recognize I was running larger injectors and it barely idled at all. basically it was like plugging 440s into into a stock computer, hehe. Anyway, I had to replace my o2, you might have to do the same. borrow a friends and see if it goes away.
Old Sep 10, 2002 | 04:22 PM
speedymon's Avatar
Default Re: Code 41, primary oxygen sensor??? (TurboInteg95)
so you fouled the O2. Please explain.
Old Sep 10, 2002 | 04:44 PM
not much else to explain. basically I ran the car rich as hell on accident for a few minutes and it threw code 41. Even after I fixed the fuel problem, it still threw code 41 until I replaced the o2.
kuks24
11
Jun 24, 2019 04:59 AM
EF8 JUNKIE9
May 2, 2004 06:14 AM
delsol93
Jun 21, 2001 02:54 PM
