lots of smoke
Old Aug 30, 2002 | 11:44 AM
inline976's Avatar
Default lots of smoke
alright, i have this problem where i blow out lots of smoke and it only happens when i've been driving really hard on it (like 6 or 7 passes). i'm running LS v-tec turbo on 5 psi. the turbo is off of a subaru which is really old. is it possible the turbo is heating up and smoke is coming from the turbo? compression test says all cylinders are good. also, nothing else is happening when all the smoke comes out. it doesn't overheat or anything. the smoke is gray really dark. plus i'm running extremely rich. help...............
Old Aug 30, 2002 | 11:57 AM
93LSivic's Avatar
Default Re: lots of smoke (inline976)
Gas if its really dark. You said your running rich.
Old Aug 30, 2002 | 12:11 PM
wonny's Avatar
Default Re: lots of smoke (93LSivic)
dark - rich!
make sure that it isn't white or you are screwed (white is oil).
Get it tuned if you can.
Dave
Old Aug 30, 2002 | 12:14 PM
CovertFI's Avatar
Default Re: lots of smoke (wonny)
(white is oil).
white is coolent
blue is oil.
if it is your turbo check your ic tubes and see if oil is in them.
Old Aug 30, 2002 | 01:43 PM
ekb18c's Avatar
Either your just runnign rich like everyone else says or the seals on the turbo are bad, you did say it's an old turbo, so there is a good chance that the turbo is gone/
ChrisCrankz96
May 3, 2013 06:34 AM
civicturbo22
Jun 8, 2005 09:54 AM
LxSedan
May 15, 2005 07:31 PM
boostedlude3g
Apr 16, 2003 07:08 PM
4gvtec
Apr 4, 2002 05:05 PM
