Blue Wire Mod - Black Box
Old Aug 30, 2002 | 09:42 AM
TURBOED-TEG's Avatar
Default Blue Wire Mod - Black Box
I have tried to do a search but it won't find anything...I can't remember how to do the blue wire mod - I am correct in saying that it will let the AFC display a A/F rating right? Also, what is this I here about "black boxes", any info would be appreciated.
Thanks ahead of time!!!
Old Aug 30, 2002 | 10:13 AM
liam821's Avatar
25 Year Member
Default Re: Blue Wire Mod - Black Box (TURBOED-TEG)
Yea..it lets you read the O2 sensor voltage with the SAFC, you cant use the VAFC. Just take the blue wire on the SAFC (its not being used) and connect it to the white o2 sensor wire....walla you have a o2 voltage meter...goto the setup menu and then "check voltages"
liam
Old Aug 30, 2002 | 10:58 AM
Default Re: Blue Wire Mod - Black Box (liam821)
What does the voltage tell me - I don't know how t interperut that...HELP
bump
Old Aug 30, 2002 | 12:43 PM
ttt
Old Aug 30, 2002 | 04:05 PM
liam821's Avatar
25 Year Member
bump
The higher the voltage the richer the car runs.
LEAN RANGE: (.050 to .249V)
STOICHIOMETRIC RANGE: (.250 to .749V)
RICH RANGE: (.750 to 1.000V)
These values also applies to the autometer A/F gauge. LEAN range is the red led, stoich is the yellow, and rich is of course the green LEDs.
You normally want to tune a turbo honda on the rich side, around .88 to .90 volts.
liam
Old Sep 5, 2002 | 12:36 PM
teg2snbtrbd's Avatar
Once the blue wire mod is done, would there be any reason to unhook it? Do you still have the ability to adjust everything once it is hooked up?
Old Sep 5, 2002 | 12:51 PM
Default Re: Blue Wire Mod - Black Box (teg2snbtrbd)
ANYONE????????
Old Sep 5, 2002 | 02:29 PM
ttt
Old Sep 10, 2002 | 07:44 PM
Hellz99si's Avatar
liam
Hey Liam....I have a VAFC, why can't I use the Blue wire mod and what is the VTM signal anyway? (What's it stand for?)
Old Sep 10, 2002 | 10:53 PM
liam821's Avatar
25 Year Member
Naw you dont have to unhook it. To check the voltages you just goto the "check voltages" menu...the rest of the time im normally at the "stats" screen.
liam
Old Sep 10, 2002 | 10:59 PM
liam821's Avatar
25 Year Member
Default Re: Blue Wire Mod - Black Box (Hellz99si)
You cant do the blue wire mod because you dont have a blue wire...hehehe The blue wire is used for the 2nd MAF sensor on a 300ZX-TT.
The VTM signal is the vtec signal i guess..i dont have one so im not sure.
liam
silverspins
Jan 19, 2005 07:04 PM
dsm this
Mar 15, 2004 02:42 AM
Urban Business
22
Sep 2, 2003 05:52 PM
loworbitSI
Oct 9, 2002 10:41 AM
Urban Business
Aug 23, 2002 01:03 PM
