How much Boost on (D) series... Stock bottom?
Hey, I just wanted to see if everyone running a d seriers would fill me in on what they got and what they are boosting on a sohc . i have a d15b7 on 5 psi Intercooled.. i need to know what to do with timing and fuel for 7-9 psi safe
[Modified by havok hybrid, 9:43 PM 9/1/2002]
Re: How much Boost on (Jared)
Come on man, you do NOT need $2000 worth of fuel management to run such a small amount of boost.
Fuel pump and 310's would be a good idea. Regulator would be nice.
Re: How much Boost on (The Walking Dude)
NICE... I found Dsm injectors... 380cc.. will that be to much for stock everything.. but i have a spoon remaped pecu for a b16
...and .. TIMING>. what is the deal with boost and timing .. pound per retard.. and after how much boost does it then need to be retarded.... ????
Re: How much Boost on (D) series... Stock bottom? (havok hybrid)
The d15b7 has some small rods, they arnt very strong. I have boosted 15psi on a stock d16z6 but the rods are much larger. I would keep the boost to 10psi or under on the little b7. You can swap in some VX rods on your b7, they are much larger and fit just fine in the b7 block.
liam
liam
Re: How much Boost on (liam821)
well this motor is just a tuner.. i want to know what is to much.. but.. i also what to get there b4 it goes... like im only on 5 psi now.. i just got a missing link so know i dont throw MAP.. but i want more boost.. so if i get injectors. what size for 7-9 psi and if dsm.. from what model .. non turbos are 290cc and auto turbos are 380cc and stick turbos are 440cc.. what should i get also.. what other injectors can i run.. can i run any injector?... off any car.. that has same plug or what
