homemadeturbo oil feed? to TD05-14G need help
hi i was wondering what fittings would i need to get to run a -4an SS braided oil feed line to my turbo? i belive the hole is a 7/16th sized hole? also for the peopel running fuel line, what fittings did you use and what size fuel line ? any problems? suggestions ? need help please !!!
Re: homemadeturbo oil feed? to TD05-14G need help (project dc2)
yes id like to know the thread pitches for the block as well...does it matter h-series and b-series or area all honda motors basically the same when it comes to the oil pressure switches thread pitch?
Re: homemadeturbo oil feed? to TD05-14G need help (fuzzy logik)
-well i know the t25 oil feed thread on the turbo is 7/16"
-and for the thread pitch for the block its a 1/8" bsp fitting. you could buy it at z10
http://www.z10eng.com/products.cfm#adpt
i believe most of the honda blocks use that size too.
Re: homemadeturbo oil feed? to TD05-14G need help (lamchop0000)
its odd
i used a 1/8 bspt on my d series
then on two b series kits i used 1/8 npt
i actually recently switced from a 1/8npt to an earls autofit -4 to 1/8npt and no leaks.
Re: homemadeturbo oil feed? to TD05-14G need help (DA666)
The thread on the back of the block should be 1/8 BSPT, you can get away with NPT though, just be carefull.
As for your 14b, well the oil feed is a 12mm standard thread I do beleive.
FOrSfEd
08-13-2004 12:03 PM
