My tranny is ANNOYING... I need help please !! Sohc Turbo !
it's a d16z6 greddy turbo
recently installed ACT HD PP with Action unsprung 6 puck
sometimes my tranny won't let me shift into first second or any other gear...
I bleeded it 2 times already...
Sometimes when i start at a red light, i can't push into first gear..
Sometimes when i turn, it won't let me shift into second gear
Sometimes when i am going into fourth gear, it slips...
HELP PLZ!
It's very very annoying !!
thanks !
HELP PLZ!
thanks !
Re: My tranny is ANNOYING... I need help please !! Sohc Turbo ! (xbird)
Start off by bleeding the clutch system. Then see what kind of adjusting you can do on the pedal itself. Then take a look into the tranny---sounds like it could be a bent shifter fork, or at worst your syncro's.
Re: My tranny is ANNOYING... I need help please !! Sohc Turbo ! (93LSivic)
Sorry to hear ure having problems, i'm going to be changing my clutch as well, just reading up the helm's manual right now. Good luck xbird
like i said i bleeded it 2 times
i looked at the fork, it's fine...
and at idle, it shifts fine, once it's running, it doesn't work
syncro's? Is there any kind of grinding or "stickyness" when you put the car into gear or change gears?
[Modified by turbocoupe, 3:18 AM 9/2/2002]
Re: My tranny is ANNOYING... I need help please !! Sohc Turbo ! (turbocoupe)
hmm...
i am not TOO sure..
but when it lets me shift, it feels the same as before...
i also have a DC sports Short shifter..
i am not TOO sure..
How new is that shifter? Mine was a little stick and hard to put into gear when I first got it.
[Modified by turbocoupe, 9:43 AM 9/2/2002]
illestrolla247
09-19-2004 08:27 PM
