WTF, I'm blowing oil out the compressor inlet!
Guest
Posts: n/a
OK I just fixed my leaking head gasket which was leaking oil everywhere, Cometic, copper spray , and ARP head studs torques to 70 ft-lbs. Now, I've got oil spraying out the compressor inlet. I've got a GSR oil pump on an LS/Vtec. I'm running -4AN line to the head Vtec oil port and teeing off that with a -3AN line to the turbo. Do I need a restrictor on the turbo oil feed? Where do I get them?
Re: WTF, I'm blowing oil out the compressor inlet! (CRV Monster)
I'm having the same sort of problem.... if you wanna input please post in my similiar thread...
https://honda-tech.com/zerothread?id=267873
Re: WTF, I'm blowing oil out the compressor inlet! (shadowdawn)
is it spraying...or just getting a oil residue around it. if its just a residue, thats pretty common and normal.
Snafu-Si
01-22-2005 10:21 AM
