stroke & bore for a d16y7 and Combustion on a d16y8?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
the compression "ratio" is established by the relationship of the cylinder head with the block, in specific, pistons, stroke and the thikness of the head gasket.
unfotunately, i don't know the CC of the chambers.
stan
stan
D16A1, D16A6: .048"
D16Z6, D16Y8: .037"
D16A1: USDM 86-89 Integra (the only USDM twincam D series engine)
D16A6: USDM 88-91 CRX/Civic Si
D16Z6: USDM 92-95 Civic Ex/Si
D16Y8: USDM 96-00 Civic Ex
I'm not sure about the D16Y7.
Sonny
[Modified by Sonny, 9:22 AM 9/2/2002]
D16Z6, D16Y8: .037"
Sonny
I have a d16y7 and I'm getting ready to put on a y8 head, will this change the compression ratio to the ex, or will it stay the same as the cx?
Nick
Nick
altho i'm wondering if you lose any low end torque?
But all you need is the ECU, harness, head, and gaskets....you can ghetto rig a RPM switch but unless you have some sort of AFC to make up for the lack of fuel when VTEC engaugs then you should get the ECU and harness....you should also considor the EX tranny as well.
_______
I wouldn't be too worried about that.
_______
_______
Rob
do you need a new cam gear when you switch the head? or just the cam, rocker arms, valves, valvesprings
..and i know hondas don't have much torque to begin with, but the d16y7 puts its max out at 4600rpm while the y8 only has 4 more lbft and it's way up at 5500rpm. i guess the increase in the top end would more than make up it, tho.
spooncivicsi
Nov 7, 2006 06:47 AM
spooncivicsi
Nov 6, 2006 09:12 AM
swrdply400mrelay
Jul 2, 2003 01:00 PM
