Help, car throwing code....
Old Sep 2, 2002 | 08:34 AM
sneakypete's Avatar
Default Help, car throwing code....
We just put a turbo on my buddies car and everything runs fine but we are getting code 10 which is intake air temp. We've reset the ecu but the check engine light comes back right when we start it up. Has anyone had this problem before and what did you do to fix this problem. The only thing that I can think is maybe the sensor is bad. Thanks
Old Sep 2, 2002 | 12:10 PM
sneakypete's Avatar
Default Re: Help, car throwing code.... (sneakypete)
bump
Old Sep 2, 2002 | 12:32 PM
T25 civic's Avatar
What kind of a setup do you have? Fuel, timming, turbo?
Nick
Old Sep 2, 2002 | 12:50 PM
sneakypete's Avatar
Default Re: Help, car throwing code.... (T25 civic)
vortech fmu (12:1), walboro 255 intank fuel pump, stock timing, t3/t4 garret turbo, tial wastegate with 5lb. spring, msd ignition, and running 4 check valves. The car runs fine, no problems at all just that damn check engine light annoys my buddy. Thanks
Old Sep 2, 2002 | 01:03 PM
T25 civic's Avatar
I didn't think you would need that big of a fuel pump with the fmu? Are you running really rich?
Nick
Old Sep 2, 2002 | 01:07 PM
sneakypete's Avatar
No its not running rich at all, when he gives it full throttle the egt gauge goes to 750 C, and thats with 91 octane. Like I said the car pulls hard for only 5 lbs. The only thing that I can think of is the sensor went bad. Thanks
[Modified by sneakypete, 10:08 PM 9/2/2002]
Old Sep 2, 2002 | 07:31 PM
sneakypete's Avatar
bump
OneTyteEK9
Mar 9, 2006 11:43 AM
radioren
Feb 11, 2005 05:38 PM
sneakypete
Sep 8, 2003 04:46 PM
hksturbolude
Sep 12, 2002 10:18 PM
