big PROBLEM with the car
Old Aug 31, 2002 | 06:11 PM
DLB1994's Avatar
Default big PROBLEM with the car
i did a compression test and came out good better the i thought i was getting 235-225psi on every pistons tonight with only 9:1 compression je pistons
The car runs the same very powerful at 10psi i can be cruising in 2nd gear and hit it letting the boost come in and start spin the tires
but every time i get in to it i see blue smoke behind me (at least it looks blue to me)
when i pull the oil cap off i see some steam coming out but not much at all but it still feel like more air coming out then normal like blow by or something but the compression test came out so good
when i had a stock engine i broke ringlanding and i could tell i was getting smoke out the valve cover then nothing like that now
i took the turbo off the manifold and it idles with no smoke at all but when i hit the gas a puff of i think blue smoke spray out vary fast and then no more smoke after i keep hitting the gas but after i go back to idle and do it again and the smoke do the same thing again
Old Aug 31, 2002 | 09:05 PM
Ri5e's Avatar
Default Re: big PROBLEM with the car (DLB1994)
Maybe the Valve oil seals are bad and oil is flowing past the valves and burning in the combustion chamber.
Old Aug 31, 2002 | 09:26 PM
DLB1994's Avatar
Default Re: big PROBLEM with the car (CRV Monster)
every thing is new in the head seals, valves, guides, 5 angle valve job
Old Aug 31, 2002 | 09:34 PM
Ri5e's Avatar
I would double check...
battosai
Aug 29, 2014 07:46 AM
Ron454321
Sep 13, 2007 02:47 PM
See Are X
Aug 13, 2005 09:25 AM
tianporn
10
Jul 20, 2004 11:24 AM
GOTNOS
Apr 16, 2003 04:37 PM
