Evaluate My Turbo Kit........Input NEEDED
Old Sep 2, 2002 | 03:01 PM
integra-modder's Avatar
Default Evaluate My Turbo Kit........Input NEEDED
.48 a/r, 60mm, TO4E
Action Clutch Dual Diaphram Clutch
AEM Engine Management System
All Oil lines and return lines...
Carsound 3" Cat
Custom DP
Custom Exhuast with Magnaflow Muffler
Custom IC Piping
Custom Turbo Manifold
Eagle Rods
HKS SSQV
JG Edlebrock Intake Manifold
NGK plugs
RC 550 CC Injectors
Ross 9.6 Pistons (-5cc)
Skunk2 Adjustable Cam Gears
Slim line Cooling fan
Spearco Front Mount IC 37"x8.5"x2.5" (with endtanks)
Tial Wastgate
Turbonettics IC Connectors
Walbro Intank 255lph fuel pump
Defi Boost Gauge
Defi EGT Gauge
Defi Oil Preassure Gauge
Defi Fuel Preassure Gauge
Defi Version 2.0 Control Unit
Please evaluate this thing and tell me anything that Im missing, wont work with each other, is cheap/shitty, or just needs to be added.
THANKS H-T!
[Modified by integra-modder, 7:11 PM 9/3/2002]
Old Sep 2, 2002 | 03:27 PM
rjardy's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (integra-modder)
yup looks like a turbo kit!
Rob
Old Sep 2, 2002 | 03:31 PM
AB16A2T's Avatar
I am not seeing a case of beer in there for when you finish installing it!! LoL, looks like a kit to me...
Old Sep 2, 2002 | 03:33 PM
mntdewred's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (AresB18BTurbo)
i'll take two
Old Sep 2, 2002 | 03:51 PM
Default Re: Evaluate My Turbo Kit........Input NEEDED (mntdewred)
Thanks guys, the more input the marrier....
Old Sep 2, 2002 | 05:05 PM
JoShYo's Avatar
Thats some serious $.. but if thats not a problem it looks good
Old Sep 2, 2002 | 05:12 PM
TurbothisLS's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (JoShYo)
you have my kit and more!
the money has been saved up for a few years now...but im having to go back to work to be able to afford it....
that reminds me, i need to call my grand parents and thank them for the 50 bucks!
Old Sep 2, 2002 | 05:32 PM
ekb18c's Avatar
yup that's a turbo kit alright, Just a few comments about it though.
But here is a question.
How many psi's are you planning to push?
9:1 comp? - Why so low?
AEM EMS - Your tuner better know how to use and config AEM properly, if not then use what your tuner knows the best.
Missing Link- You wont need it with a Standalone!
37x8.5x 2.25? - 37" for just the core?? Wow!
Magnacore wires- They suck, stick with stock NGK's.
Old Sep 2, 2002 | 05:43 PM
2K_TEG's Avatar
A few things:
1. You don't need a missing link.
2. That IC is huge! You sure you want one that big?
3. I don't know what you are planning on pushing boost wise, but you may want to consider 720cc injectors and a GM 3 bar MAP.
4. HKS SSBOV? WHY?
5. I get some cam gears other than Venom. I just don't like Venom.
Otherwise: good start!
Old Sep 2, 2002 | 05:48 PM
Default Re: Evaluate My Turbo Kit........Input NEEDED (Hallusin8.com)
do you guys mean the stock wires that came with the car?
if thats what you mean id rather save 80 bucks or whatever magnacore wires cost
Old Sep 2, 2002 | 05:51 PM
ekb18c's Avatar
yes stock wires that came with the car. Factory uses NGK for spark plug wires. So when buying wires just ask for NGK wires specific to your vehicle.
Old Sep 2, 2002 | 05:54 PM
Default Re: Evaluate My Turbo Kit........Input NEEDED (2K_TEG)
A few things:
4. HKS SSBOV? WHY?
Thanks for the help guys.
1.Missing link is left from the original turbo kit contents stuff, forgot to erase it.
2.Whats wrong with having a big IC, its sooooo sweet looking, i mean if there is a big negative to having it, then itll go out the door. but check this out. (same shop will be doing my turbo as this ITR)
3.Yes, Ive been meaning to find out more info about the wide band o2 and how much will 720cc injectors run?
4.whats wrong with it?
5.Whats bad about venom? What should I replace them with (cost)?
This will be a daily drive 95% of the time and will see the track once or twice in a season and the rest is on the road at night. Im thinking I want to run something along the lines of 12-13lbs.
Please, more input.
[Modified by integra-modder, 9:56 PM 9/2/2002]
Old Sep 2, 2002 | 06:54 PM
Please, more input.
Old Sep 2, 2002 | 07:03 PM
DC2R714's Avatar
I love my Intercooler. Go for it Modder!
Old Sep 2, 2002 | 07:11 PM
2K_TEG's Avatar
1. OK, good.
2. If you want the Big IC get it.
3. Wide Band O2 is gonna be expensive. Get you car dyno tuned, and use their's. Then if you want to add it later, good upgrade.
3b. 720cc injectors can be had for ~$300. RCs are much more.
4. I think the HKS valve sounds terrible, and I would rather have a quieter valve. I like the sound of the apexi and GReddy type R personally. More of a rush of air than a whistle.
http://www.alltrac.net/tuning/blowoffvalve.html
5. Get some Skunk Gears. Less than $200.
Old Sep 2, 2002 | 07:38 PM
1. OK, good.
3b. Which brand is this?
4. Now that I've heard it, Id rather have it not as loud, is that possible, to eliminate the whistling effect of it? (problem is that the SSQV is staring at me right now on my table...), thats a great site though.
5. Damm... 200, venom gears are 125... got anything thats good and comprably priced?
Old Sep 2, 2002 | 07:44 PM
Anyone want to trade a new HKS BOV for a new Greddy Type R? or I can do it with the place I bought mine from for 5 bucks...
Old Sep 3, 2002 | 06:20 AM
ekb18c's Avatar
IMO there is nothign wrong with the hks bov is pretty damm good. It is made well and it isn't too loud. If i would have to do it agian, I would either get hks or tial or the greddy type S.
HTH
Old Sep 3, 2002 | 06:35 AM
DC2R714's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (ekb18c)
Just FYI if you end up doing rods and pistons. You probably want to do bearings too and obviously a new headgasket.
Old Sep 3, 2002 | 08:05 AM
2K_TEG's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (DC2R714)
Good point! Def. get new bearings. Depending on how many miles you have on the motor I would get a new oil pump, new water pump, new timing belt too. Might as well do it right the first time. All that stuff is cheap too.
Look up user iloveracing. He gave me a great deal.
Kyle
Old Sep 3, 2002 | 08:14 AM
Trigun's Avatar
do you need to buy defi guages? mine are for sale and used for only 2 months.
Old Sep 3, 2002 | 08:16 AM
2K_TEG's Avatar
Default Re: Evaluate My Turbo Kit........Input NEEDED (Trigun)
I don't know what ones you have, but he was asking me for the BF series. Good luck
Old Sep 3, 2002 | 08:17 AM
Trigun's Avatar
oh nm then i have the link series. bf series
Old Sep 3, 2002 | 11:07 AM
I Like Boost's Avatar
btw skunk2 cam gears are less than $200 for the pair the venom ones are $125 each, i don't know if you understood correctly.
