Help with Autometer Air fuel ratio gauge
finally got my Autometer Air/fuel ratio gauge set up in the car, can someone please tell me what kind of readings im looking for:
At idle?
at cruising?
At WOT?
how many L.E.D's should i have lighting up??
somone please help cos i wanna make sure my car is running right before i crank up the boost
D16Z6 T3 Turbo, 12:1 FMU, S-AFC, missing link, FMIC
Deacs
At idle?
at cruising?
At WOT?
Deacs
Re: Help with Autometer Air fuel ratio gauge (turkish)
you will get all sorts of readings. autometer a/f = poop
An a/f guage running of the stock O2 will tell you if you are lean or rich. nothing more. This is still usefull information.
Re: Help with Autometer Air fuel ratio gauge (tegtyper)
Re: Help with Autometer Air fuel ratio gauge (mntdewred)
Yeah, I wouldnt do any real tuning with it, but I do think its nice to have some sort of indication that things are 'OK' for instance if you have fuel problems, and it goes real lean, you can see that and rectify the problem hopefully before you damage something.
As for a waste of money, I dunno. Compare it to the cost of an EGT. Tells you basically the same thing, and I know I wouldnt drive a FI car without at least one of those installed.
