what headgasket to use?
Old Aug 29, 2002 | 11:32 AM
swoosh1's Avatar
Default what headgasket to use?
im putting my d16y8 head on my d16y7 bottom end. what gasket will i need? and whats my compression ratio gonna be? thanx
Old Aug 29, 2002 | 05:50 PM
swoosh1's Avatar
Default Re: what headgasket to use? (swoosh1)
yoo nobody has this setup or knows what im talkin about?
i juust need to know what headgasket to use with my setup
99 D16y8 vtec head w/ 97 d16y7 block
and if u know what my compression will be that would help
thanks
Old Aug 29, 2002 | 05:53 PM
Tinker219's Avatar
I know with the Bseries setups, you use the same headgasket as the block. So you would want the HG off the D16y7. I have NO clue what your compression would be. Test it and find out.
Old Aug 29, 2002 | 08:57 PM
98civicEX's Avatar
no offense, i think you'll have more luck in the hybrid, or tech forum....and if you're runnig a mini-me swap, i believe it'll be the same as EX. cause that's basiclly what your making.
Old Aug 29, 2002 | 10:56 PM
CzanSOHC's Avatar
Default Re: what headgasket to use? (98civicEX)
I believe that the y8 is thinner then the y7....but are you going to turbo in the future? Might want to think about an aftermarket thicker headgasket if you have some big plans...but go w/ the y8 head gasket. Let me know how everything works out...Cazan82@aol.com, i'm going to be doing the same thing only building the y8 before i slap it on W/ a GReddy 2mm HG.
Old Aug 30, 2002 | 06:42 AM
swoosh1's Avatar
Default Re: what headgasket to use? (CzanSOHC)
my motors ready to go in but nobody knows what my compression will be ,and i need to know!
i need low compression and im running a y7 bottom end w/ a y8 head
Old Aug 30, 2002 | 07:40 AM
autoEXturbo's Avatar
well if you're looking at going with a lower compression headgasket, call inlinepro. I know they make one for the d series blocks and i'm sure they could help you out.
Old Aug 30, 2002 | 07:36 PM
swoosh1's Avatar
Default Re: what headgasket to use? (autoEXturbo)
ne1 know what my ciompression would be with a y8 haed and y7 bottom end?
austincrx
Jun 2, 2007 02:00 PM
gabspeed
Jan 5, 2004 09:48 AM
1swoosh
Sep 3, 2002 06:49 AM
illmatic_si
Jul 7, 2002 11:11 PM
