NPT Flange on a Greddy TD04
I would like to change the Greddy supplied oil return flange (which mounts to the turbo) to an NPT fitting so that I may use a SS line instead of the supplied rubber one. Does anyone make a flange that can replace this Greddy supplied piece?
Re: NPT Flange on a Greddy TD04 (ZCivicTurbo)
I would like to know this too. I know the topic has been covered mainly for the T3/T4 turbos, but what about upgrading the return lines for the Greddy Turbos. I know somebody has have to have dont this.
-deepsi
-deepsi
Check the link below. They have a...
"Oil Drain Flange, all Mitsubishi TDO5/6 including HRC Super: This 3/16" thick 304 stainless flange can be welded to a tube or tapped for a pipe thread. Uses gasket shown above."
Call them to see if this will work with the TD04 or if they sell a different adaptor.
http://www.hahnracecraft.com/hahn/parts/install.htm
Re: NPT Flange on a Greddy TD04 (Evil Beaver)
I have found these post on the subject, but it is unclear on the oil drain flange.
https://honda-tech.com/zerothread?id=203520
https://honda-tech.com/zerothread?id=243814
still searching
-deepsi
still searching
-deepsi
