what is going on when i hear rod knock? Rebuild
ok we just had a 97 integra motor bored out 10 over and threw in some srp's 10to1 compression and we are hearing a huge knock. at first it was quite with a little noise just like normal forged pistons then after about a min or 2 is got very much louder so cut the car off. the sounds is from the lower engine, and we reused the old bearings, it sthere a chance that its causing with im hearing? and ideas?
Re: what is going on when i hear rod knock? Rebuild (turboex)
siezed something perhaps??
you should replace the bearings and chck teh tolerances very carefully.... hope you didn't cause any other damage...
<--- my theory anyway....
Re: what is going on when i hear rod knock? Rebuild (GSRwBOOST)
the motor still turns over by hand freely, so its not siezed. but good idea. keep um coming
After market pistons normally do make a slapping noise...but its not a loud knocking noise. If its an expensive sounding noise like rod knock i highly recommend you pull the oil pan and check the rods bearings. Maybe you forgot to put one in? If you do have a rod bearing problem dont drive on it..dont even start the car..it doenst take much to distory the honda crank past the point of fixing.
liam
liam
Re: what is going on when i hear rod knock? Rebuild (liam821)
Yeah, don't run it anymore. The noise won't heal itself. Only gets worse. Pull it apart and it will probably be obvious what went wrong. Look to the rod bearings first. Easy to install the pistons or rods backwards. Could be an oiling issue. Are you sure you torqued every rod bolt?
Re: what is going on when i hear rod knock? Rebuild (earl)
You said you reused the old bearings....are you using the same rods? The stock ones? Or aftermarket?
Re: what is going on when i hear rod knock? Rebuild (MatT3T4)
same rods same bearings. did not run long enouhg to see smoke, it did run clean for the 2mins that we had it running. but after the noise got lound i ccut the car off. how can you tell if the bearing is bad?. ill check them againt o make sure there all tight. but i need to know what to look for in a bad bearing that can make noise. thanks guys
You will know a bad bearing when you see it. It will be all torn up and full of gouges, broken bits, extremely rough etc. Usually a dirrerent color metal will be partially showing in the gouge.
If want to find out which one is making the noise, start the car and run it. Pull one spark plug wire at a time. The noise will stop when you pull the plug wire of the offending piston/rod/bearing...which ever it may be....Mike
