MAX-REV users, you going thru wg gaskets like crazy?
ok, seems as though i go thru wg gaskets like nothing, surface may not be flat,am i the only one? so far ive used 2 gaskets in 2 weeks
i'm not happpy about this,i hate this type of ****. should i double up on the gaskets or what?
Re: MAX-REV users, you going thru wg gaskets like crazy? (lucas569)
I had the same problem till I ran out of 35mm gaskets so I just took the gaskets out altogether and its better now than ever before...
I think the metal to metal contact is a lot better than with the gasket, just make sure you have your ring lined up right and your good to go.
Bolt that WG up and your ready to go..
Adi
Re: MAX-REV users, you going thru wg gaskets like crazy? (newgsr)
i didn't run any gaskets .. i just sprayed some copper sealant stuff and it worked pretty good
I bet you are using the gaskets that came with the tial wg. Pick up the metal turbonetics gasket instead
Re: MAX-REV users, you going thru wg gaskets like crazy? (sparkz)
where can i get those?
Re: MAX-REV users, you going thru wg gaskets like crazy? (javierb14)
of course!
are u using the metal ring supplied with wastegate?
well i went out and bought the copper stuff, put it on and no leak SO FAR, but it's very weird my wg seems to open as soon as i hit the gas, sounds like a damn dune buggy, boost doesnt seem to build up as fast,is this cause i had a leak? and the wg didnt open casue it basicaly was venting? before i change the gasket it was quiet until i punched it and it didnt sound like a dune buggy. wtf?
i burned my wastegate gasket too so i just took off the gasket ,now everything is find.
the metal to metal contact is your best bet
mine started to make a funny noise, like air escaping. i put my finger in front of it and i could feel the hot air.
