Is VTEC noticeable on your supercharged GSR?
Old Sep 17, 2002 | 09:31 PM
H22coupe's Avatar
Default Is VTEC noticeable on your supercharged GSR?
I recently installed a JRSC on a GSR engine that I had purchased disassembled (the head, block, dist, etc. were apart). I never ran the engine without the charger and now I'm wondering if my VTEC is working ok. I can tell when VTEC is working on an NA GSR but I'm not sure about on my charged GSR. So to sum up: my question - is there a noticeable VTEC engagement on JR supercharged GSR's?
Also as a side question, have any of you found any decent power gains using adjustable cam gears with your JRSC?
Old Sep 18, 2002 | 12:27 AM
TurboR1391's Avatar
Default Re: Is VTEC noticeable on your supercharged GSR? (H22coupe)
No the switchover is not as audible as a N/A engine.
Old Sep 18, 2002 | 05:21 AM
SiRkid's Avatar
Default Re: Is VTEC noticeable on your supercharged GSR? (TurboR1391)
i second that...no more vtec growl for you
Old Sep 18, 2002 | 05:25 AM
i2un's Avatar
Audible difference....no, but the rpms should climb much faster past the v-tec point. Also if everything is hooked up correctly and you don't throw a code I'd bet v-tec is working fine and you just can't tell. If you have the money, dyno and you'll get a clear answer.
Old Sep 18, 2002 | 06:04 AM
H22coupe's Avatar
Default Re: Is VTEC noticeable on your supercharged GSR? (i2un)
Thanks for the replies. Never threw a VTEC related code either so I guess everything is working ok.
Old Sep 18, 2002 | 03:19 PM
Speedworks801's Avatar
You'll hear it through a 3" exhaust I promise.
finest_GSR
Apr 6, 2006 09:09 PM
gsrallday
Nov 7, 2003 12:14 PM
icelarry27
Mar 2, 2003 09:53 AM
White S2k
11
Oct 30, 2002 11:07 PM
JDMchris
May 20, 2002 11:46 AM
