boost gauge? 0 at idle?
If you're using a diesel-powered engine, that would be normal
If the engine is off, it will sit at 0, but if you've started the engine already, it should show vacuum..
what are you tapping for your vacume source?
i bet he is not taping it into the manifold and had it in line with his ic pipes that is the only way that is possible
You would not see 12 pounds of boost at half vacuum.
"on throttle a bit, just normal driving, about 7 vac"
thats the gauge following the bernoulli principle (higher velocity, lower pressure) in the charge pipe.
"boost goes up to 12"
thats the gauge reading the charge pipe
