F-max vs drag
Old Sep 20, 2002 | 07:43 AM
fastlude69's Avatar
Default F-max vs drag
whats the better kit? i don't want to go custom and you can get the fmax with ball bearing so it spools faster. plus the fmax give more power then the drag and also has detontion management. any responces from people with these setups will be greatly appreicated
Old Sep 20, 2002 | 11:16 AM
SIK IN DA HED's Avatar
New User
Default Re: F-max vs drag (fastlude69)
you can get a ball bearing upgrade with a DRAG kit. FMAX aint all that you think it is. "detonation management? i wouldnt consider a MSD 6BTM exactly detonation management... nor 2 extra injectors and the mf2 "fuel management". especially for the price...
Old Sep 20, 2002 | 01:24 PM
spectunedphil's Avatar
Default Re: F-max vs drag (dlplayboy)
drag all they way
Old Sep 20, 2002 | 01:28 PM
DR. ON POINT's Avatar
Banned
Default Re: F-max vs drag (hondadriven)
just do some research and buy some used pieces like intercooler pipes and **** like that.....u will save a hell of a lot of money
ohh and Drag sucks unless u like to overboost and swap out manfiolds because theirs crack
Old Sep 20, 2002 | 01:31 PM
Etylorcen's Avatar
Default Re: F-max vs drag (On Point EK)
The only time people really have trouble with boost creep on drag kits is with a full 3'' dp and exhaust. As for cracking manifolds, that has been a bad rumor for a long time.
Old Sep 20, 2002 | 02:08 PM
fastlude69's Avatar
Default anyone got a f-max
does anyone have a f-max they run at higher psi? I wanna know what has the best parts if i know already fmax manifold is better then the drag but aren't they the same turbo? both hybrid t3/t4 just the added management is nicer.
Old Sep 20, 2002 | 03:03 PM
GruvyTune's Avatar
New User
Default Re: anyone got a f-max (fastlude69)
order an fmax manifold and do the rest yourself!
its a nice manifold and will accomodate most t3/t04 turbos.
Old Sep 20, 2002 | 03:53 PM
Banned
Default Re: F-max vs drag (Etylorcen)
exactly....I run and so most other turbod hondas run 3in exhausts........
and if the drag manifold cracking issue is just a rumor how come I have a couple friends with fucked up cracked drag manifolds siiting around????
Old Sep 20, 2002 | 06:17 PM
IntegD's Avatar
New User
My manifold worked fine for more than a year now, 12psi. I guess i just got lucky then?
Old Sep 20, 2002 | 06:25 PM
niedejb's Avatar
Im running an fmax mani @ 13 psi
Old Sep 20, 2002 | 07:01 PM
shadowdawn's Avatar
Default Re: anyone got a f-max (niedejb)
Yea I heard drag 3 manifolds are more prone to cracking and boost spiking...
My rev hard is old (used for 20-30k, cause I bought it used) not cracked, and at 8psi and 2.5 DP and full 3" exhaust I get NO SPIKE whatsoever, and never heard of anyone with a rev-hard mani getting spikes....
Spikes I hear are more prone to manifold design then anything else, because of where the wg is mounted etc... air blow out too fast past the wg to the turbo before the wg gets to see the pressure and in turn causes the turbo to spin past the desired setting.
Drag 3 kit with hondata and rev hard mani =
Old Sep 20, 2002 | 08:07 PM
sutrusu's Avatar
Default Re: anyone got a f-max (shadowdawn)
how is the max rev for boost spikes?
Old Sep 20, 2002 | 08:36 PM
Banned
Default Re: anyone got a f-max (sutrusu)
there will be no boost spikes with max rev
Old Sep 20, 2002 | 08:42 PM
tony1's Avatar
Default Re: anyone got a f-max (GruvyTune)
I think the rev hard is a much better designed manifold than the fmax. I would recommend the rev hard...no cracks or boost spikes (unless you have a deltagate as they always seem to spike).
Old Sep 20, 2002 | 09:26 PM
flip1199's Avatar
Default Re: anyone got a f-max (tony1)
How about this kit.
http://216.231.62.86/index.php?site=dsp_customTurboKit
Old Sep 21, 2002 | 05:41 AM
tony1's Avatar
Default Re: anyone got a f-max (flip1199)
Looks like pretty good deal, but what it really comes down to is how good everything fits. There are so many kits out there that don't fit good and are ugly.
Old Sep 21, 2002 | 08:32 AM
GruvyTune's Avatar
New User
anyone know if another brand downpipe will fit with my fmax manifold/t3-t04E turbo? i'm sick of the stupid wastegate slipjoint letting exhaust out of it.
its a stupid design that way. anyone have any remedy to that? I hate to use a c clamp on the hard steel it may crack.
Old Sep 21, 2002 | 09:48 AM
SlowTeg's Avatar
If it's a slip joint than a clamp is the only way to fix the leak. If it still leaks, the slip joint is probably too loose and you might have to get it redone.. In that case though you might as well just use flanges.
Mike
Old Sep 21, 2002 | 10:15 AM
DeeJay's Avatar
New User
Forget the f-max vs drag wars, whatever! I have the fmax and am happy with the end result. I didn't get the extra injectors and mf2 and had them make my dp open loop. The quality of the kit is very good. the dp is 2.5", has a 12" flex section on it, it has the right flange to bolt to the cat. the intercooler pipes fit perfectly. The problem I had was f-max's service was horriable. They sent me the wrong downpipe and inncorect spec turbo. they wouldn't send me the new parts until I sent them the wrong ones back ! This caused my running car to sit on jacks for 2 weeks until i finally got the parts back.
ejectseat
Feb 23, 2003 02:08 PM
idreamsi
Oct 20, 2002 03:09 AM
Pat
Oct 9, 2002 10:05 PM
Evil EG
May 21, 2002 11:27 PM
