Thicker d16y8 head gasket? help!
Old Sep 20, 2002 | 10:01 AM
tyrant's Avatar
Default Thicker d16y8 head gasket? help!
i got my greddy d16a thicker head gasket in today, tomorrow im going to try to put it on my d16y8 block, will it fit perfectly or will it not work?
its the only thicker head gasket i could find, and the greddy gasket says 92-95 d16a, and when i lined it up with a stock d16y8 head gasket i got from honda, 2 of the bottom bolt holes do not line up exactly, i also got arp head studs so i hope everything goes in good
Old Sep 20, 2002 | 12:36 PM
inspyral's Avatar
Default Re: Thicker d16y8 head gasket? help! (tyrant)
The two center holes on the bottom(the side closest to the front of the car) are for the dowel pins, so I'm thinking you need those to line up right.
Old Sep 20, 2002 | 12:47 PM
CovertFI's Avatar
Default Re: Thicker d16y8 head gasket? help! (inspyral)
some guy posted on here that arp does not make any head studs for the d16y8 only the 5th gen civics
Old Sep 20, 2002 | 12:59 PM
mntdewred's Avatar
Default Re: Thicker d16y8 head gasket? help! (CovertFI)
then he got his information wrong cause i have some sitting in front of me..
Old Sep 20, 2002 | 01:08 PM
skilzz's Avatar
Default Re: Thicker d16y8 head gasket? help! (mntdewred)
ok well the last time I installed the 92-95 grex (greddy 2mm) head gasket on my d16y8 it fit absolutely perfect...NO MODDING NEEDED it goes right on and bolts right up.
PS just pay close attention to the way the gasket fits, its not entirely idiot proof.
[Modified by maddskilzz, 5:10 PM 9/20/2002]
Old Sep 20, 2002 | 04:52 PM
BoostedED9's Avatar
Default Re: Thicker d16y8 head gasket? help! (maddskilzz)
i should be putting my grex gasket on my d16z6.. hope nothing gets in the way, ill be using arp's for this too...
Old Sep 20, 2002 | 07:02 PM
D-Man's Avatar
Default Re: Thicker d16y8 head gasket? help! (ED9Hybrid)
about the ARPs for Ds,they only make one set of headstuds to cover all the Ds from 88 and up,only time youll have problems is when u mix and match heads to blocks,i used a D16z block with a D16y head,had a problem with 2 of the ARP studs being too long,the D16Y has two head bolt pads lower than either the D16A or D16Z head but it aint a problem if you use the D16Y block,cause those two holes are deeper in the block.
Old Sep 20, 2002 | 08:10 PM
00civicvtec's Avatar
Default Re: Thicker d16y8 head gasket? help! (D-Man)
So the D16 ARP head studs WILL work in a D16Y8 longblock? Can anyone confirm this that has actually done it?
I need to know because I will be assembling my D16Y8 LB soon with some D16 ARP head studs...
Old Sep 20, 2002 | 08:35 PM
D-Man's Avatar
Default Re: Thicker d16y8 head gasket? help! (00civicvtec)
yes,they will work with an all d16y motor,all the bolts are the same length as a D16Z or D16A,only diff is that the D16Y block has those two deeper holes in the block to make up the diff in the head.
Old Sep 20, 2002 | 08:47 PM
Thanks, I was worried there for a minute
Old Sep 20, 2002 | 09:33 PM
98civicEX's Avatar
damn, i'm using a z6 block w/ a y8 head...how do i fix this then?
Old Sep 20, 2002 | 10:26 PM
liam821's Avatar
25 Year Member
The greddy head gasket worked perfect on the y8.
As for as the ARP head bolts..i dont think they work. The y7/y8 head bolts are much shorter then the z6..so they wont work.
Im not sure if ARP makes the right sized bolts...but the a6/z6 wont work.
liam
Old Sep 20, 2002 | 10:49 PM
Smashback's Avatar
Default Re: Thicker d16y8 head gasket? help! (liam821)
So just shorten the studs. All you'd have to do is cut some thread off the block side and wala.
Old Sep 21, 2002 | 08:47 AM
D-Man's Avatar
Default Re: Thicker d16y8 head gasket? help! (mplex2000)
i asked an ARP tech about that,he said thats a bad idea and recommended against it,he said its a better idea to use a couple of extra arp washers instead,so thats what i did.
Old Sep 21, 2002 | 10:03 AM
D-Man's Avatar
liam
I cant speak for the y7 cause i havnt check it out yet but on a Y8,all the head bolts are the same length as a Z6,I know this from checking a Z6 and Y8 all apart and side by side trying to figure out why 2 of the ARP studs where sitting higher when i mounted the Y8 head on Z6 block.
Old Sep 21, 2002 | 10:27 AM
tyrant's Avatar
the head gasket went on perfectly, everything went back on fine, just it seems that the timing belt is making a wineing noise of some sort.....
and i got the newest arp head studs, when i talked to the sales person they said there was an older model number that had longer studs and this newer model was a little shorter...so i went with the shorter and it worked fine
now i just have to fix this damn noise
Old Sep 21, 2002 | 08:33 PM
D-Man's Avatar
you might have the timing belt adjusted too tight,itll make the oil pump sing like that.
Old Sep 21, 2002 | 08:53 PM
tyrant's Avatar
well the timing belt tensioner doesnt want to move worth a ****, i even tried moving the powersteering out of the way and it seems to be in there good.....any suggestions?
Old Sep 21, 2002 | 09:08 PM
D-Man's Avatar
Did you loosen up the 14mm bolt that goes thru the center of the tensioner?
Old Sep 22, 2002 | 06:04 PM
tyrant's Avatar
i tried loosening it up, pulled the cap off of it and its not loosening up at all
LSteggyguy
20
Dec 2, 2017 04:49 PM
EK9JSPEC
Apr 11, 2013 08:59 AM
khmoe
Jan 14, 2009 02:05 PM
