Help me settle disagreement......(hondata)
Old Sep 18, 2002 | 01:24 PM
Mr. Vapor's Avatar
Default Help me settle disagreement......(hondata)
Ok, so my friend (the self proclaimed turbo expert hehe) and me are in a discussion about The Hondata system and basically im arguing that it will make your car behave as a factory tuned turbo, no need to "hide" boost etc etc.
just new ecu, hondata, injectors and away you go.
Hes arguing that you'll need a GM 3 bar map sensor, becuase if my stock sensor sees over 13lbs of boost it will spike and possibly damage the sensor and give the sensor incorrect readings.
i was always under the impression that the point of hondata is that so you dont have to "hide" the boost from the ECU, it knows its there, and therefor a Stock MAP will work...
so my question:
Do you need to upgrade the MAP when going Hondata. Is it possible to "spike" a map sensor (in his words)
or
do you simply keep the stock MAP, no missing link, no 3bar nothing......
Old Sep 18, 2002 | 01:26 PM
done's Avatar
Default Re: Help me settle disagreement......(hondata) (NYb16)
you need gm 3 bar map, for boosting over 11lbs...and you need resistor box for peak and hold injectors, same with aem
Old Sep 18, 2002 | 01:28 PM
racerxadam's Avatar
you have the option to use either map sensor. in order for the ecu to provide correct fueling for boost levels over ~12 psi you have to use a 3 bar sensor. I don't think running higher boost will hurt the sensor but the voltage that the sensor outputs won't change above~12psi
Old Sep 18, 2002 | 01:30 PM
DeepSi's Avatar
You only need to upgrade the Map sensor if you are boosting above 13 psi. The reason for that is because Stock map sensor were not meant/designed to read pressure that high. so you need to get another sensor that can read higher. stock works up to 13 psi, and some people have argued it can go higher, but it is safe to upgrade when you get to 13 psi.
You are not hiding the boost, you are allowing the ecu to be able to read the pressure with the map sensor.
Old Sep 18, 2002 | 02:14 PM
Mr. Vapor's Avatar
Default Re: Help me settle disagreement......(hondata) (DeepSi)
ah, now i understand! thanks guys, knew i could count on you!
looks like i have to go admit i was wrong!
Old Sep 18, 2002 | 02:17 PM
civic disobedience's Avatar
I was just on the phone with AEM this mornning, they told me 12psi is fine on a stock map sensor, "my 2 cents"
Old Sep 18, 2002 | 02:19 PM
poison's Avatar
Default Re: Help me settle disagreement......(hondata) (civic disobedience)
how much does the GM one usually run
Old Sep 18, 2002 | 02:24 PM
Dee's Avatar
Dee
Default Re: Help me settle disagreement......(hondata) (poison)
OEM Honda sensor is a 2 bar but taking it past 11psi is like driving a bulldozer on a frozen lake after the first freeze.
1bar = 0psi
2bar = 14.5psi
3bar = 29psi
Old Sep 18, 2002 | 03:21 PM
GruvyTune's Avatar
New User
uhm..just my $1000....I blew my motor because i boosted over 12psi on the stock map sensor and the hondata system went haywire and probably went lean and detonated.
Do NOT use the stock map sensor anything over 11psi.
Old Sep 18, 2002 | 03:55 PM
liam821's Avatar
25 Year Member
Default Re: Help me settle disagreement......(hondata) (Jordo)
I boost 12psi on a stock map sensor daily and have boosted 14.5-15psi also without a problem. Its a 2bar sensor so it should read 14.7psi (at the limits) although i know some people have problems...but i havent.
thanks,
liam
Old Sep 18, 2002 | 04:44 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default Re: Help me settle disagreement......(hondata) (liam821)
thanks,
liam
OK just logic here but 2 bar map sensor will see just that. 2 bars. maybe a little bit less because the factory 1 bar map sensor will only see 11 psi. So why not just go all out and get the 3 bar? Its like 80 bucks from hondata...
Old Sep 18, 2002 | 05:00 PM
TurboedGSR's Avatar
Default Re: Help me settle disagreement......(hondata) (Boosted2ksi)
its cheaper from autozone
Old Sep 18, 2002 | 06:18 PM
liam821's Avatar
25 Year Member
the factory MAP sensor is a 2bar. The 3bar and the 2bar still use 0-5 volts...so unless you have a standalone, ie hondata or aem EMS, you are going to mess up your fuel maps. The honda ECU was designed to use a 2bar sensor..not 3.
liam
Old Sep 18, 2002 | 07:14 PM
Dee's Avatar
Dee
2bar = 14.5psi
atmospeheric pressure = 14.7psi
Everybody confuses those two!
One more: 1kg/cm(2) = 14.22psi
[Modified by Dee, 11:25 PM 9/18/2002]
Old Sep 18, 2002 | 08:49 PM
9krpm's Avatar
um. I thought thats what we were talking about here? Hondata? That was the original question of the thread. I disagree. Well for my car anyways. I had a 2 bar map sensor for a minute...only for about a week until i got my 3 bar. It let me see more than 11 psi of boost. THe factory one did not.
Old Sep 18, 2002 | 10:54 PM
Dee's Avatar
Dee
Many people have taken OEM Honda map sensors past 11psi with success but the sensor isn't very reliable after 11psi.
Old Sep 19, 2002 | 11:27 AM
liam821's Avatar
25 Year Member
Default Re: Help me settle disagreement......(hondata) (Dee)
2bar = 14.5psi
thanks
Old Sep 19, 2002 | 06:00 PM
Dee's Avatar
Dee
No problemo! Josh Madison's convert program is an excellent source for number crunching and conversions.
Cabletie
Engine Management and Tuning
11
Jan 4, 2017 09:25 AM
lucidvtec
Jul 11, 2005 11:51 PM
b16 matt
Sep 21, 2004 07:00 AM
Anubyss
Oct 18, 2002 05:35 AM
