I hate these types of ?'s but i need your input
here's a guy's set-up, that i just recently saw. i was curious to what you guys think this would run in the 1/8th (no 1/4 track here). it's a b20 w/ b16 head under jrsc boost. when it was just a sir2 under 6psi of boost, it was hitting 9.11 in 1/8th
JE 10.5:1 pistons
Crower rods
Total Seal file-fit ring set
OE rod and main bearings
Z-10 aluminum main girdle
GSR main bolts
GSR windage tray
GSR oil pick-up
GSR oil pan
Type "R" oil pump
Type "R" water pump
GSR timing belt
ARP head studs
OE CRV headgasket
Russel #4AN VTEC oil feed line
Z-10 oil pump feed fitting
All accessory hardware (alternator, A/C, brackets, sensors, etc) was transferred from his original JDM B16A SiR-II engine.
Head:
JDM B16A Sir-II stock head
STR cam seal
JRSC with stock components and a GSR crank pulley
Venom 310cc injectors
Cartech 2025i FMU
JR MAP mod
JR BTC
JR VPAC
Transmission:
JDM B16A cable with HASport conversion
Quaife LSD
ACT HD clutch with street/strip disc
Fidanza lightweight flywheel
[Modified by 98civicEX, 7:49 PM 9/19/2002]
JE 10.5:1 pistons
Crower rods
GSR main bolts
GSR windage tray
GSR oil pick-up
GSR oil pan
Type "R" oil pump
Type "R" water pump
GSR timing belt
ARP head studs
OE CRV headgasket
Head:
STR cam seal
Cartech 2025i FMU
JR MAP mod
JR BTC
JR VPAC
Transmission:
Quaife LSD
flycivicsi
03-14-2013 06:10 PM
