wat is needed to retard my timing
Old Sep 18, 2002 | 02:54 PM
zcivic91's Avatar
Default wat is needed to retard my timing
im getting tired of messing with my distributor everytime i want to run the n2o..is there sumtin i can buy from msd or somewhere that i can retard my timing a few degrees on demand?
Old Sep 18, 2002 | 02:56 PM
sutrusu's Avatar
Default Re: wat is needed to retard my timing (zcivic91)
msd btm
Old Sep 18, 2002 | 03:07 PM
niedejb's Avatar
Default Re: wat is needed to retard my timing (sutrusu)
The btm uses boost to retard timing not n2o pressure.
Old Sep 18, 2002 | 03:46 PM
TurboedGSR's Avatar
Default Re: wat is needed to retard my timing (niedejb)
msd digital 6 plus, jacobs mastermind (jacobs sucks), crane hi-6 with retard option, and I belive mallory also makes a unit for a cheaper price. they all have a feather touch rev limiter (2 stage on the msd) and a retard timing only when nitrous is activated
Old Sep 18, 2002 | 04:00 PM
zcivic91's Avatar
Default Re: wat is needed to retard my timing (TurboedGSR)
i already have a msd 6a...im looking for sumtin not too expensive..
wat ru n2o guys using??
Old Sep 18, 2002 | 05:41 PM
ninesecrx's Avatar
A msd 6a is not a digital 6 ign. like he was saying...you can control stuff like that. NOS makes a unit that will do it as well, but im sure its a little pricey.
Old Sep 18, 2002 | 05:48 PM
KoRE's Avatar
Digital 6 all the way
Old Sep 18, 2002 | 05:49 PM
p0gi's Avatar
Default Re: wat is needed to retard my timing (ninesecrx)
MSD makes an in cockpit unit similiar to the crane unit that allows 15 degrees of adjustment. You can find it at summit part # msd-8680 . Works in conjunction with your 6a box . Its $96
Old Sep 18, 2002 | 06:41 PM
zcivic91's Avatar
Default Re: wat is needed to retard my timing (p0gi)
hmm that peice looks good..
how does it work though? does it advance and retard?? or just one or the other??
Old Sep 18, 2002 | 06:46 PM
SiRkid's Avatar
most aftermarket ignition companies have a system that can retard timing
[Modified by SiRkid, 3:47 AM 9/19/2002]
Old Sep 18, 2002 | 09:34 PM
p0gi's Avatar
Default Re: wat is needed to retard my timing (SiRkid)
I havent used it but I believe you can set your distributor, and then retard up to 15 degrees .
boosted k20
Apr 5, 2005 07:04 AM
2.2XDreams
May 24, 2004 12:34 PM
99lspwr
Mar 4, 2004 10:37 AM
cliff666
Dec 20, 2003 02:03 PM
96LudeSiVTEC
Feb 23, 2003 11:54 AM
